Gmsh generates a mesh with 0 nodes 0 edges 0 faces...
bernd
Re: Gmsh generates a mesh with 0 nodes 0 edges 0 faces...
Postby bernd » Thu Apr 09, 2020 12:01 pm
ahh there was something with occt ...
Did you install the distribution version, or did you compile gmsh yourself?
rpardeza
Postby rpardeza » Thu Apr 09, 2020 12:10 pm
I've done what you said in two ways:
1) Starting gmsh thu linux menu and openning the brep file: trying a '3D' mesh, gsmh stalls.
2) Starting gmsh thu command line: gmsh crashes with the following error:
~$ /usr/bin/gmsh /tmp/Box_Geometry.brep
Delaunizing vertices...
Delaunay seconds:  0.002583
Creating surface mesh ...
Surface mesh seconds:  0.000773
Recovering boundaries...
Boundary recovery seconds:  0.000885
Removing exterior tetrahedra ...
Exterior tets removal seconds:  0.000102
Recovering Delaunayness...
gmsh: /build/tetgen-OYksSp/tetgen-1.5.0/tetgen.cxx:4879: double tetgenmesh::insphere_s(double*, double*, double*, double*, double*): Assertion `oriB != 0.0' failed.
[Gerion:27641] *** Process received signal ***
[Gerion:27641] Signal: Aborted (6)
[Gerion:27641] Signal code:  (-6)
[Gerion:27641] [ 0] linux-gate.so.1(__kernel_rt_sigreturn+0x0)[0xb7fcbd20]
[Gerion:27641] [ 1] linux-gate.so.1(__kernel_vsyscall+0x9)[0xb7fcbd09]
[Gerion:27641] [ 2] /lib/i386-linux-gnu/libc.so.6(gsignal+0xc2)[0xb696c832]
[Gerion:27641] [ 3] /lib/i386-linux-gnu/libc.so.6(abort+0x121)[0xb696dcc1]
[Gerion:27641] [ 4] /lib/i386-linux-gnu/libc.so.6(+0x257bb)[0xb69647bb]
[Gerion:27641] [ 5] /lib/i386-linux-gnu/libc.so.6(+0x25819)[0xb6964819]
[Gerion:27641] [ 6] /usr/lib/i386-linux-gnu/libtet.so.1.5(_ZN10tetgenmesh10insphere_sEPdS0_S0_S0_S0_+0x1b1)[0xb644d6d1]
[Gerion:27641] [ 7] /usr/lib/i386-linux-gnu/libtet.so.1.5(_ZN10tetgenmesh12lawsonflip3dEPNS_15flipconstraintsE+0x1cd)[0xb64818ad]
[Gerion:27641] [ 8] /usr/lib/i386-linux-gnu/libtet.so.1.5(_ZN10tetgenmesh15recoverdelaunayEv+0x1de)[0xb64875ee]
[Gerion:27641] [ 9] /usr/lib/i386-linux-gnu/libtet.so.1.5(_Z14tetrahedralizeP14tetgenbehaviorP8tetgenioS2_S2_S2_+0xb04)[0xb64988b4]
[Gerion:27641] [10] /usr/lib/i386-linux-gnu/libtet.so.1.5(_Z14tetrahedralizePcP8tetgenioS1_S1_S1_+0x365)[0xb649c525]
[Gerion:27641] [11] /usr/lib/i386-linux-gnu/libgmsh.so.3(_Z24MeshDelaunayVolumeTetgenRSt6vectorIP7GRegionSaIS1_EE+0x1018)[0xb72f18d8]
[Gerion:27641] [12] /usr/lib/i386-linux-gnu/libgmsh.so.3(_Z18MeshDelaunayVolumeRSt6vectorIP7GRegionSaIS1_EE+0x5b)[0xb72f27cb]
[Gerion:27641] [13] /usr/lib/i386-linux-gnu/libgmsh.so.3(_Z12GenerateMeshP6GModeli+0x2677)[0xb72880a7]
[Gerion:27641] [14] /usr/lib/i386-linux-gnu/libgmsh.so.3(_ZN6GModel4meshEi+0x1c)[0xb708e1cc]
[Gerion:27641] [15] /usr/lib/i386-linux-gnu/libgmsh.so.3(_Z10mesh_3d_cbP9Fl_WidgetPv+0x20)[0xb762b230]
[Gerion:27641] [16] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_ZN9Fl_Widget11do_callbackEPS_Pv+0x54)[0xb6869d64]
[Gerion:27641] [17] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_ZN9Fl_Button6handleEi+0x2a7)[0xb6811d67]
[Gerion:27641] [18] /usr/lib/i386-linux-gnu/libfltk.so.1.3(+0x3008b)[0xb680908b]
[Gerion:27641] [19] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_ZN2Fl7handle_EiP9Fl_Window+0x2c9)[0xb680b1e9]
[Gerion:27641] [20] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_ZN2Fl6handleEiP9Fl_Window+0x3a)[0xb680b5aa]
[Gerion:27641] [21] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_Z9fl_handleRK7_XEvent+0x8c5)[0xb6871465]
[Gerion:27641] [22] /usr/lib/i386-linux-gnu/libfltk.so.1.3(+0x9a146)[0xb6873146]
[Gerion:27641] [23] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_Z7fl_waitd+0x18a)[0xb687334a]
[Gerion:27641] [24] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_ZN2Fl4waitEd+0x1ab)[0xb680abeb]
[Gerion:27641] [25] /usr/lib/i386-linux-gnu/libfltk.so.1.3(_ZN2Fl4waitEv+0x30)[0xb680ac90]
[Gerion:27641] [26] /usr/lib/i386-linux-gnu/libgmsh.so.3(_ZN5FlGui4waitEv+0x1d)[0xb762256d]
[Gerion:27641] [27] /usr/lib/i386-linux-gnu/libgmsh.so.3(_ZN12openglWindow12selectEntityEiRSt6vectorIP7GVertexSaIS2_EERS0_IP5GEdgeSaIS7_EERS0_IP5GFaceSaISC_EERS0_IP7GRegionSaISH_EERS0_IP8MElementSaISM_EERS0_I7SPoint2SaISQ_EERS0_IP5PViewSaISV_EE+0x10c)[0xb76420dc]
[Gerion:27641] [28] /usr/lib/i386-linux-gnu/libgmsh.so.3(_ZN5FlGui12selectEntityEi+0x42)[0xb7623702]
[Gerion:27641] [29] /usr/lib/i386-linux-gnu/libgmsh.so.3(+0x97b939)[0xb763a939]
[Gerion:27641] *** End of error message ***
Abortado (`core' generado)
rpardeza
Postby rpardeza » Thu Apr 09, 2020 12:12 pm
I installed the distribution version
bernd
Postby bernd » Thu Apr 09, 2020 1:21 pm
I have no idea ... Linux Mint Forum or gmsh mailing list? Or compile yourself.
Ahh there is another one you could try.
- create a simple box in FreeCAD
- export to stl
- try to open gmsh with this
- try to mesh
- it it works your gmsh misses OpenCascade I would assume.
rpardeza
Postby rpardeza » Thu Apr 09, 2020 3:47 pm
Done. I can make a mesh from stl file. No problem.
cubo.msh.txt
(2.18 KiB) Downloaded 4 times
rpardeza
Postby rpardeza » Thu Apr 09, 2020 4:00 pm
I can make a 2D mesh with FreeCAD but no a 3D one or a "From Shape".
bernd
Postby bernd » Thu Apr 09, 2020 5:17 pm
From my point of view there is an issue with gmsh binary and opencascad library. It seams any operation which includes opencascade make gmsh to fail.
We had similar, but different problem. https://forum.freecadweb.org/viewtopic.php?t=32176 The user solved it by download of a binary from gmsh homepage. I remember some years ago I had problems too. I did compile it myself.
Bernd
bernd
Postby bernd » Thu Apr 09, 2020 5:18 pm
The strange thing is mint is based on ubunutu. On ubuntu and debian gmsh from repo works.
rpardeza
Postby rpardeza » Thu Apr 09, 2020 7:50 pm
Ok, thank you very much for your help.
