[Solved]CalculiX FEM Freq Analysis: No nodes found in Frd file.
johnwang
Re: CalculiX FEM Freq Analysis: No nodes found in Frd file.
Post by johnwang »
fandaL wrote: Fri May 01, 2020 10:58 am
*STEP
*FREQUENCY
10,0.0,10000.0
(Isn't this by default written by FreeCAD?)
I tested. It is written by FC.
Frd file only includ two lines.
    1C
 9999
After that change, got 10 result.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
seppelw
Post by seppelw »
johnwang wrote: Fri May 01, 2020 10:51 am Mine is 20839.
Hello John,
very disappointing that the Problem from 0.19.18xxxx was solved in 20802 and now has the same Problem again in 20839. Any Idea who could take care of that?
could you please send me the Help->About->Copy to clipboard information? I'd like to file a Bug,... or if you like you can do it yourself?
Thanks a lot for your help, great to have feedback.
Best Regards, Seppel
Hello fandaL,
not sure, I changed it to 10kHz in the preferences when I was doing some simulations earlier, if I remember right... so that was my fault I guess.
Default was however 1Mhz or something like that. Guess it's always limited?
Thank you very much for your amazing help, awesome :D Not it works, and I understand what was wrong. Very nice!
johnwang
Post by johnwang »
seppelw wrote: Fri May 01, 2020 11:20 am
Hello John,
Just the ccx is not included in the Zip file. Last time there was no gmsh.
I copyied the ccx from the old version to a folder in the serch path, so no problem.
seppelw
Post by seppelw »
Hello John,
but I think that is an issue when FC is released the next time. I guess there is a script compiling/copying all the packages,... . Maybe it's a manual process and that's the issue, if it would be automated that wold solve it properly?
Best Rgeards, Seppel
sgrogan
Post by sgrogan »
seppelw wrote: Fri May 01, 2020 1:10 pm but I think that is an issue when FC is released the next time. I guess there is a script compiling/copying all the packages,... . Maybe it's a manual process and that's the issue, if it would be automated that wold solve it properly?
ccx and gmesh are not in the Libpack, so I have to download and mange them separately. Unless someone pings me I don't update them often. Its better if the user manages these packages themselves, and set the paths to the executables in prefs.
Anyway it will be fixed in the next bundle.
"fight the good fight"
bernd
Post by bernd »
the normal windows package includes ccx as well as gmsh! Might be if you switch between installed, conda, whatever package ccx or gmsh binary path is just wrong!
sgrogan
Post by sgrogan »
bernd wrote: Fri May 01, 2020 1:47 pm the normal windows package includes ccx as well as gmsh! Might be if you switch between installed, conda, whatever package ccx or gmsh binary path is just wrong!
I've had some issues lately including these in the Libpack builds. Hopefully this is fixed for a while :(
johnwang
Post by johnwang »
sgrogan wrote: Fri May 01, 2020 1:45 pm ccx and gmesh are not in the Libpack, so I have to download and mange them separately. Unless someone pings me I don't update them often. Its better if the user manages these packages themselves, and set the paths to the executables in prefs.
l prefer not include these two for develop version at least.Downloaded them so many times.
edub
Re: [Solved]CalculiX FEM Freq Analysis: No nodes found in Frd file.
Post by edub »
I just had this problem
11:41:49  FEM: No nodes found in Frd file.
11:41:49  Problem on frd file import. No nodes found in frd file.
11:41:49  FEM: No result object in active Analysis.
when using
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
The code for Calculix written by FreeCAD is as follows:
** At least one step is needed to run an CalculiX analysis of FreeCAD
** written by write_step_begin function
*STEP
*FREQUENCY
10,0.0,10000.0
The default Megaherz gives the same issue.
Is this problem showing its head again or am I doing something wrong? Any ideas for me?
Thanks in advance!
