hfcMYSTRAN - a test case
HoWil
Re: hfcMYSTRAN - a test case
Post by HoWil »
johnwang wrote: Fri May 29, 2020 11:25 pm Why volume mesh? This is a shell.
:D because I am curious if I/we can use it for meshing volumes
johnwang
Post by johnwang »
CBAR with a TUBE profile
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
johnwang
Post by johnwang »
CBAR with a T2 profile
johnwang
Post by johnwang »
mystran's all-elem-test.dat case. A plain supported by some frames.
FC doesn't support mixed meshes now, so have to draw twice, one with faces and the other one with edges. But for animation, only one could be viewed at one time.
HoWil
Post by HoWil »
johnwang wrote: Sat Jun 13, 2020 4:05 am mystran's all-elem-test.dat case. A plain supported by some frames.
You did apply a force or? Is it a face load or is it only one force on the middle line of the face?
johnwang
Post by johnwang »
HoWil wrote: Fri Jun 19, 2020 2:02 pm
PLOAD2 on CQUAD4 & CTRIA3 shell
SubCase 91
johnwang
Post by johnwang »
Mystran now support CBUSH now. This is a test case from https://github.com/dr-bill-c/MYSTRAN/issues/11
bernd
Post by bernd »
I gave Mystran a try. I installed https://github.com/ceanwang/hfcMystran to read the result file into FreeCAD but I got an error message ...
14:02:03  Running the Python command 'hfcMystranNeuInWire' failed:
  File "/home/hugo/.FreeCAD/Mod/hfcMystran/hfcMystranNeuInWire.py", line 203, in Activated
    iniFout = open(inifileOut,"w")
[Errno 2] Datei oder Verzeichnis nicht gefunden: '/usr/local/Mod/hfcMystran/hfcMystran.ini'
Where do I get this ini file from? Is it really needed to read the results?
cheers bernd
johnwang
Post by johnwang »
bernd wrote: Wed Jul 14, 2021 12:04 pm
[Errno 2] Datei oder Verzeichnis nicht gefunden: '/usr/local/Mod/hfcMystran/hfcMystran.ini'[/code]
You can create one txt file. Just one line of the path where you last opened the case file.
bernd
Post by bernd »
johnwang wrote: Wed Jul 14, 2021 12:16 pm
Did not work either. I might did something wrong. Nevermind ... https://github.com/ceanwang/hfcMystran/pull/1 I added some code to use the standard FreeCAD way to open or import a file.
You did a great work with these importer :D
