[Fixed] 0.19pre, FEM fail to startup in Conda build
UR_
Re: 0.19pre, FEM fail to startup
Postby UR_ » Fri May 15, 2020 9:30 am
Conda builds are broken ATM
FEM WB and MeshDesign WB are affected.
https://forum.freecadweb.org/viewtopic. ... en#p398697
ickby
Re: [Bug] 0.19pre, FEM fail to startup
Postby ickby » Fri May 15, 2020 1:58 pm
ahh nice, works flawless with the LibPAck version. Thanks!
fc_tofu
Postby fc_tofu » Fri May 15, 2020 3:03 pm
Thanks for your message.
fc_tofu
Re: [Fixed] 0.19pre, FEM fail to startup in Conda build
Postby fc_tofu » Tue May 19, 2020 10:47 am
This bug is removed in latest build.
OS: Windows 10 (10.0)
Version: 0.19.21097 (Git)
Hash: a5ab09aa0941cc945e59848897b160f8cbfc0831
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
felixlee868
Postby felixlee868 » Tue May 19, 2020 12:38 pm
I report bug on MacOS
The next information are display when I switch to FEM WB
/User/Stupidness/miniconda3/envs/freecad/lib/Fem.so, 2): Symbol not found: __ZN6netgen7testoutE
Referenced from: /Users/lifeng/miniconda3/envs/freecad/lib/libNETGENPlugin.8.3.dylib
Expected in: /Users/lifeng/miniconda3/envs/freecad/lib/libmesh.so
in /Users/lifeng/miniconda3/envs/freecad/lib/libNETGENPlugin.8.3.dylib
File "<string>", line 64, in Initialize
Run Env information:
MacOS 10.15.4
conda 4.8.2
OS: macOS 10.15
Qt version: 5.12.5
OCC version: 7.4.0
I think somebody's typo let new version crash when run FEM WB.
Please fix this problem.
Best Regards
fc_tofu
Postby fc_tofu » Thu May 21, 2020 9:25 am
When using "Create mesh from shape by Netgen" command, I got failure. But different than yours.
So, the issue has not been recovered completely.
But my OP's title is about "startup", so we'd better talk it in new thread.
<Exception> Access violation
1e-07 <App> Document.cpp(3693): Failed to recompute Unnamed#FEMMeshNetgen: Access violation
3.72235 <App> Document.cpp(3693): Failed to recompute Unnamed#FEMMeshNetgen: Access violation
Recompute failed! Please check report view.
8.53945 <App> Document.cpp(3693): Failed to recompute Unnamed#FEMMeshNetgen: Access violation
18.8938 <App> Document.cpp(3693): Failed to recompute Unnamed#FEMMeshNetgen: Access violation
115.558 <App> Document.cpp(3693): Failed to recompute Unnamed#FEMMeshNetgen: Access violation
Qt version: 5.12.5
OCC version: 7.4.0
felixlee868
Postby felixlee868 » Thu May 21, 2020 9:47 am
I have found the problem. Due to netgen version.
Please use netgen old version. e.g 6.2.1808
DON'T USE NETGEN VERION 6.2.2004. THIS VERSION WILL CRASH FEM WB !!!
