Fenics as Solver
HoWil
Re: Fenics as Solver
Postby HoWil » Sun May 27, 2018 2:28 pm
joha2 wrote:
Sun May 27, 2018 10:03 am
HoWil wrote:
Sat May 26, 2018 2:57 pm
Can you please test if inner boundaries are already accessible jet? :?:
Hey HoWil,
as far as I know, inner boundaries should not be a problem. Since for my "heizung" example there is a room with an inner "heizung" volume which could be used as volume heat source via the cell function interface and as inner boundary condition via the facet function interface. I will have a look at your example during the next few days.
Best wishes
Johannes
Hi Johannes,
Thanks in advance for your help!
Is it maybe possible to share your "heizung" example, so I can compare it with my work?
BR,
HoWil
joha2
Postby joha2 » Sat Jun 02, 2018 8:14 am
Hey HoWil,
sorry for the long delay. The code for the "heizung" example is as follows (I did not remove the comments for using the cell function):
# import Fenics main module
import fenics as fe
# import FreeCAD modules
import FreeCADGui
import FreeCAD
# import Fenics interface classes
from feminout.importFenicsMesh import writeFenicsXDMF
from femsolver.fenics.fenics_tools import CellExpressionXDMF, FacetFunctionXDMF
set Python executable to an appropriate value to maintain instant functionality
during the make process
import sys
sys.executable = '/usr/bin/python'
#fe.set_debug_level(fe.DBG)
Select mesh in active document and export it to a temporary file
sel = FreeCADGui.Selection.getSelection()
if len(sel) == 1 and FreeCAD.ActiveDocument is not None:
	sel = sel[0]
	writeFenicsXDMF.write_fenics_mesh_xdmf(sel, "mesh.xdmf")
Choose charge expressions via Fenics' expressions classes
eaussen = fe.Expression("-10.0", degree=1)
einnen = fe.Expression("-5.0", degree=1)
eheizung = fe.Expression("10.0", degree=1)
eheizung_volume = fe.Expression("0.1", degree=1)
Use Fenics interface class to import temporary mesh.
Use labels from mesh groups and use expressions for Dirichlet boundary conditions.
ff = FacetFunctionXDMF("mesh.xdmf",
	{"innen":{"type":"Dirichlet", "value":einnen},
	"aussen":{"type":"Dirichlet", "value":eaussen}, #}),
    "heizung":{"type":"Dirichlet", "value":eheizung}})
#cf = CellExpressionXDMF("mesh.xdmf", {"heizung_volume":eheizung_volume}, degree=1)
lambda_air = fe.Constant(26.2)
In the following use simple Fenics example for Poisson equation to calculate
an electrostatic type potential on the mesh and with the mentioned boundary conditions.
V = fe.FunctionSpace(ff.mesh, "Lagrange", 1)
#W = fe.FunctionSpace(cf.mesh, "Lagrange", 1)
u = fe.TrialFunction(V)
v1 = fe.TestFunction(V)
#v2 = fe.TestFunction(W)
#dx_heizung = cf.dx["heizung_volume"](1)
f = fe.Constant(0.0)
my_form_lhs = lambda_air*fe.inner(fe.grad(u), fe.grad(v1))*fe.dx
#my_form_rhs = cf*v2*dx_heizung
my_form_rhs = fe.Constant(0.0)*v1*fe.dx
#print(fe.assemble(1*cf.dx["heizung_volume"]))
#print(fe.assemble(1*cf.dx["heizung_volume"](0)))
#print(fe.assemble(1*cf.dx["heizung_volume"](1)))
print(fe.dx)
#print(cf.dx["heizung_volume"](1))
u = fe.Function(V)
fe.solve(my_form_lhs == my_form_rhs, u, ff.getDirichletBCs(V))
PVD file can be inspected by using Paraview
fe.File("sol_fc_fenics_raum_mit_heizung.pvd") << u
Further note that in the cut the inner boundaries have a temperature of 10 degrees like expected for the "heizung".
I hope that the macro code and the example geometry helps.
Best wishes
Johannes
raum_mit_heizung.zip
(19.99 KiB) Downloaded 30 times
HoWil
Postby HoWil » Sun Jun 03, 2018 6:57 pm
Hi Johannes,
Nice model. I could run it and examined the results in paraview.
Nevertheless, I can reproduce my problem with accessing the inner boundaries :!: :shock:
Please try the following code with your example and look for the result of the integral over the face 'heizung' :
print(fe.assemble(1*ff.ds['aussen'](1)))  # gives correct 2610000.0 mm²; area of 'outer' window and door
print(fe.assemble(1*ff.ds['innen'](1)))  # gives correct 1710000.0 mm²; area of 'inner' door
print(fe.assemble(1*ff.ds['heizung'](1)))  # gives 0.0 !! ; should result 2680000,00 mm²
BR,
HoWil
BTW: usually is mixing of different references a problem when creating a mesh. You have used the boolean-fragment 'raum_heizkoerper' as main Part for the gmsh-mesh 'raummesh' but than you mixed faces of 'raum_heizkoerper' and some of its child 'heizkoerper' (for 'heizung').
Tested with:
OS: Ubuntu 18.04 LTS
Version: 0.18.13780 (Git)
Build type: None
Hash: 9fb122008b99ea2d30ed3e6f7cc93a3b7717cce5
Python version: 2.7.15rc1
OCC version: 7.2.0
EDIT and on
Version: 0.18.13886 (Git)
looo
Postby looo » Sun Jun 03, 2018 9:03 pm
nice progress!
I tried running it with py3 and there was a problem somewhere in the writeFenicsXDMF function:
  File "/home/lo/.FreeCAD/Macro/fenics1.py", line 33, in <module>
  File "/home/lo/conda/conda-bld/freecad-debug_1522865186960/work/Mod/Fem/feminout/writeFenicsXDMF.py", line 266, in write_fenics_mesh_xdmf
    mesh_function_codim = dim_cell - FreeCAD_Group_Dimensions[mesh_function_type]
<class 'KeyError'>: (b'Face',)
version info:
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13827 (Git)
Branch: osx-conda-config
Hash: a285204fd9a509499410a747943765b8b545dfb9
Python version: 3.6.5
Qt version: 5.6.2
OCC version: 7.2.0
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
joha2
Postby joha2 » Mon Jun 04, 2018 6:25 am
I will test it. My conjecture is that due to inner and outer surfaces at inner boundaries and when you multiply each area element with some inner and the corresponding outer normal vector, their sum is identically zero. Maybe to correct this behaviour we have to make those boundaries real outer boundaries, i.e. we have to remove the inner part of "heizung" and make it hollow. :idea: Would that be an option?
Thanks for the hint. The usage of boolean-fragments and references is still not very clear to me, so I did it in a way which works. So what would the best practise way to do it? :mrgreen:
Best wishes
Johannes
joha2
Postby joha2 » Mon Jun 04, 2018 6:28 am
nice progress!
So now is the question: Does this come from my definition of the mesh_function_type or from the return value of the meshgroup within FreeCAD? :mrgreen: :D I will check that. Thanks for the hint @looo.
Best wishes
Johannes
looo
Postby looo » Mon Jun 04, 2018 7:28 am
you are right. So fem_mesh.getGroupElementType(g) is expected to return default string? If this is true we have to change from PyBytes_FromString to PyUnicode_FromString.
looo
Postby looo » Mon Jun 04, 2018 8:04 am
HoWil
Postby HoWil » Mon Jun 04, 2018 11:34 am
Yes, this is an option.
EDIT: I am not entirely sure if this is necessary. For boundary definition directly in fenics one does not need any knowledge of normal vectors and so on. I will try to prepare an example.
BR,
HoWil
HoWil
Postby HoWil » Sat Jun 16, 2018 9:10 am
Hi Johannes,
I tested the integration over an inner boundary in a minimal fenics example where I created the geometry and mesh in fenics and the result is the same. I get zero when simply integrating over such an inner boundary.
So there has to be a solution inside fenics.
I am thinking of using the normal vector in combination with an inner product but did not succeed until now.
Do you have any new ideas about that?
Br,
Howil
