Fenics as Solver
joha2
Re: Fenics as Solver
Postby joha2 » Sun Jul 15, 2018 10:57 am
HoWil wrote:
Sat Jun 16, 2018 9:10 am
Hi Johannes,
I tested the integration over an inner boundary in a minimal fenics example where I created the geometry and mesh in fenics and the result is the same. I get zero when simply integrating over such an inner boundary.
So there has to be a solution inside fenics.
I am thinking of using the normal vector in combination with an inner product but did not succeed until now.
Do you have any new ideas about that?
Br,
Howil
Heyhey HoWil,
sorry for the late reply, but I was on vacation the last two weeks. First to your question:
Since my experience in Fenics is quite limited I also was not able to extract the normal vector information from the boundary. I will check whether it is possible to access different points or facets of the boundary from a facet function. From that you could easily calculate the normal vector from e.g. three points A, B, C by using (A - B) x (B - C)/||(A - B) x (B - C)||. Maybe it would also be nice to make an accessible object which extracts these quantities in the Fenics tools :-) Another possibility would be to calculate the normal vector direclty from an expression if you know your boundary analytically (i.e. for a sphere with center C it is just (x - C)/||x-C||). Hope this helps a bit.
Now to the Fenics interface: I refactored the interface such that you can load the facet functions and cell functions directly from an XDMF reader class. Also the mesh is available there which you need to define the vector spaces. They could be used as before, but now you can also define vector expressions for the cell functions (i.e. to define a current or something like this). I think the interface becomes more and more useful. Although due to the value_shape() method in the Expression class I had to define an ugly class hierarchy. Maybe this could be removed in the future. The PR is created on bernds femdev branch. Maybe you could give me your opinion.
In a few days I will provide some code for solving a vector Poisson equation or something like this.
Best wishes
Johannes
joha2
Postby joha2 » Sat Apr 06, 2019 9:48 am
Hey guys,
due to one of the last PRs (https://forum.freecadweb.org/viewtopic.php?f=17&t=35171) the Fenics JIT compiler works now from a macro. This can be used to calculate FEM simulations with a FEMMesh from FreeCAD. Still missing:
  • Fenics simulation is done directly in Python code, therefore no interface necessary, but maybe needed
  • Embedding into Analysis structure (not necessary right now)
  • Creating of result object from Paraview solution files
Any suggestions?
Best wishes
Johannes
HoWil
Postby HoWil » Tue Jul 30, 2019 4:47 pm
For all still interested in using fenics in combination with FC .... I found this nice tutorial (using FC only for the geometry, and gmsh for creating the mesh externally) and thought sharing could maybe help somebody
https://comphysblog.wordpress.com/2018/ ... ng-fenics/
joha2
Postby joha2 » Tue Jul 30, 2019 5:36 pm
Nice tutorial @HoWil! I am still interested in Fenics + FC. Unfortunately the Fenics guys changed in the 2019.1 release something in the XDMF format, such that mesh transfer with markers is not working anymore. Anyway, I just prepared a docker file to create a Fenics image together with the libraries necessary to compile FreeCAD with Python3 + Qt5. This was necessary since they abandoned Python2 compatibility in Fenics. So Fenics together with FreeCAD works in principle, but the mesh transfer is not so easy anymore. Annoying is, that they use still Slack for their team communication and it prohibits to view old messages (aka know-how) before not switching to a paid plan. :cry:
Best wishes
Johannes
HoWil
Postby HoWil » Tue Jul 30, 2019 6:28 pm
Good to hear that... I once again searched a click-and-play alternative to comsol and finally ended up with fenics but it is not ready to do a quick study on a complex geometry within 5mins
Please let me know if you have anything to test.
BR,
HoWil
joha2
Postby joha2 » Wed Jul 31, 2019 4:22 pm
BR,
HoWil
Yeah, they also know about this issue and they are discussing how to simplify this workflow. They said, that in the past they focused more on complicated physics and simple geometry. I have this docker file to test, but what would be the best for the user? A fully automated installation and compile process such that at the end the FreeCAD binary is ready to go in some directory? Or just the docker image with all packages to compile FreeCAD for yourself?
Did the normal vector discussion from last time lead to anything useful for your last problem?
Best wishes
Johannes
ickby
Postby ickby » Thu Aug 22, 2019 1:28 pm
I found a problem with the XDMF export. If GMSH creates 2nd order elements they are exportet with <TopologyType="tet_10"> which brings the XDMF importer of fenics to crash. It is also not XDMF compliant. It does work with 1st order elements as this exports<TopologyType="tetrahedron"> which is supported. Maybe a warnign should be given to the user that second order is not supportet and the export should fail?
keep up the good work!
joha2
Postby joha2 » Fri Aug 23, 2019 6:32 am
Hey Ickby,
Thanks for reviewing the code. I already realized this problem, since my Fenics crashes, too, if I forget to reduce mesh order to one :mrgreen:. I also thought about using a warning message, but I was not sure whether this is the best way to go. In the XML export, the warning message is printed, and I think the mesh order reduction is done automatically. For XDMF I didn't do that because Paraview showed a valid mesh, even with tet_10 or other higher order elements. Long story short: you're right, printing a warning gives the user at least a hint that for a valid Fenics mesh the order should be reduced to one. I will implement this in the next few days.
Best wishes
Johannes
