I am trying to set the Mode and Filed of display options by program when import the VTK result file.
I want to set Mode = 'Surface'. But it doesn't work. Also tried Mode=1.
And there is no property called Field.
Need run update()? Or this function is not exposed to python?
Regards,
John
import FreeCAD,FreeCADGui
import Fem
import os, os.path
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
inipath=FreeCAD.getHomePath()
try:
path = QFileDialog.getExistingDirectory(None,QString.fromLocal8Bit("Select Directory"),inipath) # PyQt4
except Exception:
path = str(PySide.QtGui.QFileDialog.getExistingDirectory(None,str("Select Directory"),inipath)) #PySide
print (path)
grpVTK =FreeCAD.ActiveDocument.getObject('vtkResults')
if grpVTK==None:
grpVTK = FreeCAD.ActiveDocument.addObject("App::DocumentObjectGroup",'vtkResults')
for name in os.listdir(path):
if name[len(name)-4:len(name)]=='.vtu' or name[:len(name)]=='.vtk':
#print (name)
ivtk_result_obj = FreeCAD.ActiveDocument.addObject("Fem::FemPostPipeline",name)
ivtk_result_obj.read( path+"/"+name)
ivtk_result_obj.touch()
ivtk_result_obj.Mode=1
#ivtk_result_obj.field=1
grpVTK.addObject(ivtk_result_obj)
FreeCAD.ActiveDocument.recompute()
FreeCADGui.SendMsgToActiveView("ViewFit")
print ('Import results done.')
