[SOLVED] Error when postprocessing a simulation containing a *SPRING card¶
Re: [FC error] Error when postprocessing a simulation containing a *SPRING card¶
Where is the SPRING now?
The mesh has two edges, I assume these are the springs. As you know from other topic mesh ViewOrovider does not supoort mixed meshes, thus they are bot explizit shown. But with Python you can "see" them.
It works perfectly. I just replace the last function
def compact_mesh
Then, I open the frd file containing the results of Calculix and I postprocess the results in FC.
best regards,
Ekaitz.
