Now I am struggling with selfweight too...
I try to do the elmer-beam tutorial with FC and elmerGUI itself.
Using m/kg/s-units as in tutorial works (with elmerGUI).
But:
When exporting the gmsh-mesh as unv and loading in elmerGUI (mm units), the face numbers are mixed
and the result is wrong. Deflection should be approx 54 mm, not 400 mm.
For the tip-load F=2000 N alone it works, but how to set selfweight?
FC-file and case-sif from elmerGUI. Gravity points in -y.
Header
CHECK KEYWORDS Warn
Mesh DB "." "."
Include Path ""
Results Directory ""
End
Simulation
Max Output Level = 5
Coordinate System = Cartesian
Coordinate Mapping(3) = 1 2 3
Simulation Type = Steady state
Steady State Max Iterations = 1
Output Intervals = 1
Timestepping Method = BDF
BDF Order = 1
Solver Input File = case.sif
Post File = case.vtu
End
Constants
Gravity(4) = 0 -1 0 9820.0
End
Body 1
Target Bodies(1) = 2
Name = "Body 1"
Equation = 1
Material = 1
Body Force = 1
End
Solver 1
Equation = Linear elasticity
Procedure = "StressSolve" "StressSolver"
Variable = -dofs 3 Displacement
Calculate Stresses = True
Exec Solver = Always
Stabilize = True
Bubbles = False
Lumped Mass Matrix = False
Optimize Bandwidth = True
Steady State Convergence Tolerance = 1.0e-5
Nonlinear System Convergence Tolerance = 1.0e-7
Nonlinear System Max Iterations = 20
Nonlinear System Newton After Iterations = 3
Nonlinear System Newton After Tolerance = 1.0e-3
Nonlinear System Relaxation Factor = 1
Linear System Solver = Iterative
Linear System Iterative Method = BiCGStab
Linear System Max Iterations = 500
Linear System Convergence Tolerance = 1.0e-10
BiCGstabl polynomial degree = 2
Linear System Preconditioning = ILU0
Linear System ILUT Tolerance = 1.0e-3
Linear System Abort Not Converged = False
Linear System Residual Output = 10
Linear System Precondition Recompute = 1
End
Equation 1
Name = "elastic"
Active Solvers(1) = 1
End
Equation 2
Name = "resultFEM"
End
Material 1
Name = "wood"
Density = 7.0e-7
Poisson ratio = 0.05
Youngs modulus = 12000.0
End
Body Force 1
Name = "selfweight"
Stress Bodyforce 2 = -6.874e-3
End
Boundary Condition 1
Target Boundaries(1) = 6
Name = "fixing"
Displacement 3 = 0
Displacement 2 = 0
Displacement 1 = 0
End
Boundary Condition 2
Target Boundaries(1) = 1
Name = "load"
Force 2 = -0.4
End
- elmer_result_tutorial.JPG (81.73 KiB) Viewed 1773 times
