Linear / Non-linear Static >> 4-Parts with 4-plastic materials tutorial and results
Hello All
here I like to provide a tutorial and the results of simulations of 4 parts and 4 plastic materials,
as linear and non-linear simulation’s in different load cases.
Here the link how to get plastic material stress and strain values incl. calculation sheets
https://forum.freecadweb.org/viewtopic.php?f=18&t=51756
Ideas or feedback for iumprovement are welcomed
Greetings
Nanayaw
Greetings
Nanayaw
- FEM_Material_Non_Linear_Mat_Values_for_INP.zip
- (3.85 KiB) Downloaded 100 times
- FreeCAD_Import_Materialdaten.zip
- (3.52 KiB) Downloaded 97 times
- 4_Parts_Design_FEM_Definiert.FCStd
- (770.06 KiB) Downloaded 99 times
- Simulation_4Parts_4Materials_Linear_Static_RESULTS.pdf
- (921.65 KiB) Downloaded 133 times
- Simulation_4Parts_4Materials_Linear_Static Setup.pdf
- (499.83 KiB) Downloaded 120 times
Re: Linear / Non-linear Static >> 4-Parts with 4-plastic materials tutorial and results
wow this is cool stuff.
Would it be possible to add it to the wiki and may be write some words here and there? https://wiki.freecadweb.org/FEM_Module#Tutorials
Hello Bernd
it will be possible but first i like to get validation results from ansys as an reference
At the moment i m working on a macro to get more automatization inside I hope this weekend I will provide it
Greetings
Nanayaw
Greetings
Nanayaw
Hello Bernd
Greetings
Nanayaw
Greetings
Nanayaw
Hello All
as promised here a macro wizard to get more automatization see pictures
Start
After Macro
The macro contains some fault and is not finished but in a condition to show what it is doing
If somebody could help to get it running then it will be nice feature cause it work like a wizard
Following functions are implemented
>> Creating Boolean Fragment (CompSolid) = Funktion = OK
>> Creat Analyse Container = Funktion = OK
>> Ask by input box how much materials should created = Function OK
>> Ask by input box how much non-linear materials should created = Function OK
>> Ask for Gmsh target mesh size by input box = Function OK
>> Create Gmsh container = !!!! Function will be executed but from my thinking the part (CompSolid) must be selected because at starting the
meshing process the error occurs >>> Unexpected error when creating mesh: <class 'AttributeError'>
>> Create a mesh groupe by yes / no input box = Function = Function OK
>> By creating the mesh group the target mesh size is asked by input box = Function OK
>> Create a Fixed constrain container = Function OK
>> Create a Force constrain container = Function OK
>> Start Meshing if no mesh region is selected (no refinement) = Function >> NOT IMPLEMENTED
Additional features not set yet
>> If non linear material is selected then suggest that the mesh elements should 1st order because with non linear materials the 2nd order will occur errors during solving
>> Start Meshing after setting the mesh group regions >> It could be done macro wait until min one mesh group areas is selected and the mesh region window closed
here the complete code, I tried my best by knowing that there will be mybee faults or unneeded code parts.
I hope we get it running
Thanks and Greetings
Nanayaw
Start
After Macro
import FreeCAD
import FreeCADGui
import ObjectsFem
import Fem
import FemGui
import BOPTools.SplitFeatures
from PySide import QtGui
from PySide import QtCore
# This macro should help prepare a multi-part-analysis as much as possible with automatization |
# Create a Bollean Fragment CompSolid
j = BOPTools.SplitFeatures.makeBooleanFragments(name=QtGui.QInputDialog.getText(None, "Part Label", "Enter new label:")[0])
j.Objects = Gui.Selection.getSelection()
j.Mode = 'CompSolid'
j.Proxy.execute(j)
j.purgeTouched()
j.recompute(True)
for obj in j.ViewObject.Proxy.claimChildren():
obj.ViewObject.hide()
# Creat FEM Analysis Container
Gui.activateWorkbench("FemWorkbench")
ObjectsFem.makeAnalysis(FreeCAD.ActiveDocument, 'Analysis')
FemGui.setActiveAnalysis(FreeCAD.ActiveDocument.ActiveObject)
ObjectsFem.makeSolverCalculixCcxTools(FreeCAD.ActiveDocument)
FemGui.getActiveAnalysis().addObject(FreeCAD.ActiveDocument.ActiveObject)
FreeCAD.ActiveDocument.recompute()
# Create the materials you will asked about the amount of materials and non Linear materials
#Input material amount needed
anzah=QtGui.QInputDialog.getInt(None, "Input", "How much materials are needed:")[0]
#Input non-linear material amount needed
anzahNL=QtGui.QInputDialog.getInt(None, "Input", "How much NON-LINEAR materials are needed:")[0]
if anzahNL ==0 & anzah >0:
while anzah > 0:
FemGui.getActiveAnalysis().addObject(ObjectsFem.makeMaterialSolid(FreeCAD.ActiveDocument))
#FreeCADGui.ActiveDocument.setEdit(FreeCAD.ActiveDocument.ActiveObject.Name)
anzah = anzah - 1
print (anzah)
else:
while anzah > 0:
anzah = anzah - 1
FemGui.getActiveAnalysis().addObject(ObjectsFem.makeMaterialMechanicalNonlinear(FreeCAD.ActiveDocument, FreeCAD.ActiveDocument.getObject('MaterialSolid')))
#Create a Gmsh container with question if mesh region for refinement is also needed
# Here is a problem the gmsh container is placed but after meshing an error occurs
# >>> Unexpected error when creating mesh: <class 'AttributeError'>
# I think it is because the part(CompSolid) was not selected
#Input mesh size needed
mshsiz=QtGui.QInputDialog.getDouble(None, "Input", "Enter your target mesh size (0 = automatic):")[0]
j=ObjectsFem.makeMeshGmsh(FreeCAD.ActiveDocument, 'FEMMeshGmsh')
#FreeCAD.ActiveDocument.ActiveObject.Part = FreeCAD.ActiveDocument.Cylinder
j.CharacteristicLengthMax = mshsiz # from msgbox input mesh size
reply = QtGui.QMessageBox.question(None, "", "Did you like to select a mesh region for refinement?",
QtGui.QMessageBox.Yes | QtGui.QMessageBox.No, QtGui.QMessageBox.No)
if reply == QtGui.QMessageBox.Yes:
# Dialog for selecting mesh regions for refinement
App.activeDocument().addObject("Fem::ConstraintForce","ConstraintForce")
App.activeDocument().ConstraintForce.Force = 1.0
App.activeDocument().ConstraintForce.Reversed = False
App.activeDocument().ConstraintForce.Scale = 1
App.activeDocument().Analysis.addObject(App.activeDocument().ConstraintForce)
# This deactivated code below I don't know if its needed it should be checked
# for amesh in App.activeDocument().Objects:
# if "ConstraintForce" == amesh.Name:
# amesh.ViewObject.Visibility = True
# elif "Mesh" in amesh.TypeId:
# aparttoshow = amesh.Name.replace("_Mesh","")
# for apart in App.activeDocument().Objects:
# if aparttoshow == apart.Name:
# apart.ViewObject.Visibility = True
# amesh.ViewObject.Visibility = False
App.activeDocument().addObject("Fem::ConstraintFixed","ConstraintFixed")
App.activeDocument().ConstraintFixed.Scale = 1
App.activeDocument().Analysis.addObject(App.activeDocument().ConstraintFixed)
# if "ConstraintFixed" == amesh.Name:
# Creat mesh groupe and open the dialog for refinement
mshrefsiz=QtGui.QInputDialog.getDouble(None, "Input", "Enter your target refinement mesh size (0 = automatic):")[0]
k=ObjectsFem.makeMeshRegion(FreeCAD.ActiveDocument, FreeCAD.ActiveDocument.FEMMeshGmsh)
k.CharacteristicLength =mshrefsiz
# If no mesh region for refinement is selected
if reply == QtGui.QMessageBox.No:
# Run Gmsh and create the mesh >> that only will be done if no refinement must be done
# here the gmsh process should start
Nanayaw
- Result_Macro.FCStd
- (14.13 KiB) Downloaded 71 times
- Before_Macro.FCStd
- (6 KiB) Downloaded 88 times
Hello All
the analysis with Ansis is done and I will review it this week
and then I will share the results and a compare result between
FreeCAD and Ansis
Greetings
Nanayaw
FreeCAD and Ansis
Greetings
Nanayaw
COOL! Looking forward to the result comparison!
Hello James
last week we was bussy, hopefully coming week I could provide.
A 100% compare will not be possible cause Ansys handle things different
specially it is not possible to cerate a mesh with 1th Order, but we will see.
Greetings
Nanayaw
Greetings
Nanayaw
- Pauvres_honteux
Hello All
here the results, they are different.
I will try to also get the von mieses stress
Any ideas why the results are suxch different?
Greetings
Nanayaw
Greetings
Nanayaw
- Simulation_4Parts_4Materials_Linear_Static_RESULTS.odp
- (646.23 KiB) Downloaded 81 times
