FEM_FrontISTR: A parallel nonlinear finite element analysis workbench for FreeCAD
Post by Kunda1 »
Found on gitlab (im not the author)
FEM_FrontISTR is a FreeCAD addon that enables a parallel nonliner FEM solver FrontISTR.
FrontISTR(japanese web site): https://www.frontistr.com/
Repo: https://gitlab.com/FrontISTR-Commons/FEM_FrontISTR
twangrt
Re: FEM_FrontISTR: A parallel nonlinear finite element analysis workbench for FreeCAD
Post by twangrt »
Cool, but someone more educated must enlighten me about "parallel finite element analysis".
Found this: https://www.sciencedirect.com/science/a ... 499090211J
I searched the FrontISTR english manual, and found only one tutorial labeled "Linear static analysis, Parallel". Seems it divides the calculation in to X separate calculations. Which is neat, but does it save computing time on a single computer?
https://manual.frontistr.com/en/tutoria ... al_02.html
bernd
Post by bernd »
Wow, seams Japanese.
johnwang
Post by johnwang »
twangrt wrote: Sun Feb 07, 2021 7:41 pm separate calculations. Which is neat, but does it save computing time on a single computer?
Single computer with multi cores, if you manage well, it should faster than single core.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
twangrt
Post by twangrt »
johnwang wrote: Wed Feb 10, 2021 12:04 pm Single computer with multi cores, if you manage well, it should faster than single core.
Yes, of course. But most solvers are using multithreading, I thought "parallel" was a more unique method.
johnwang
Post by johnwang »
tutorials
https://manual.frontistr.com/en/tutorial/index.html
tutorial/01_elastic_Hinge
johnwang
Post by johnwang »
tutorial/06_plastic can
plastic can.jpg (97.44 KiB) Viewed 3917 times
johnwang
Post by johnwang »
tutorial/04_hyperelastic_spring
johnwang
Post by johnwang »
tutorial/03_hyperelastic_cylinder
johnwang
Post by johnwang »
tutorial/09_contact_hertz
