collection of material issues
bernd
Re: collection of material issues
Post by bernd »
9.
https://github.com/FreeCAD/FreeCAD/blob ... .FCMat#L17 The minus is no minus ...
# with minus
ThermalConductivity = 25.83e-3 W/m/K
# from Nitrogen card
ThermalConductivity = 25.83e−3 W/m/K[
try in FreeCAD
from FreeCAD import Units
Units.Quantity('25.83e−3 W/m/K')
will return
ValueError: syntax error
it is like a this
Units.Quantity('123abc456 m')
IMHO this should not be handled in FEM but in FreeCAD Base.
What we could do is write some method to check the values as I started here: https://github.com/FreeCAD/FreeCAD/blob ... ls.py#L452
bernd
Post by bernd »
git commit 0afa4bd3441a fixes the Nitrogen card
uwestoehr
Post by uwestoehr »
bernd wrote: Wed Jul 14, 2021 6:46 pm git commit 0afa4bd3441a fixes the Nitrogen card
many thanks!
However, we have now a bad regression:
- launch the material card editor
- open the existing Air.FCMat material card part of FreeCAD
- click e.g. on the electric conductivity
result: the value vanishes immediately.
Click now e.g. an the relative permittivity and this value does not vanish but is set to 1.
In both cases you loose the info.
bernd
Post by bernd »
uwestoehr wrote: Wed Jul 14, 2021 7:12 pm However, we have now a bad regression:
No this has not been added lately. Check out 4596f441bf0dad9d907613dcc729f040fdf7bb15 this is the parent commit of the first one I made in the regard of Materials lately. See https://github.com/FreeCAD/FreeCAD/comm ... d/Material the problem has been there before. I have played around. It seams the Material Editor rounds any value on 2 diggits. Since this is not only for displaying but it really changes the values this is a nasty bug ...
bernd
Post by bernd »
- Start FreeCAD.
- switch to FEM
- add a Analysis
- add fluid Material
- add Air
- ok
- run code:
 App.ActiveDocument.MaterialFluid.Material
{'CardName': 'Air', 'Density': '1.204 kg/m^3', 'Description': 'Dry air properties at 20 Degrees Celsius and 1 atm', 'DynamicViscosity': '1.80e-5 kg/m/s', 'ElectricalConductivity': '1e-12 S/m', 'Father': 'Gas', 'KinematicViscosity': '1.511e-5 m^2/s', 'MolarMass': '28.965', 'Name': 'Air', 'PrandtlNumber': '0.7', 'RelativePermittivity': '1.00059', 'SpecificHeat': '1.01 kJ/kg/K', 'ThermalConductivity': '0.02587 W/m/K', 'VolumetricThermalExpansionCoefficient': '0 m^3/m^3/K'}
- double click on MaterialFluid
- edit in MaterialEditor
- double click in any value
- ok
- ok
{'CardName': 'Air', 'Density': '1.20 kg/m^3', 'Description': 'Dry air properties at 20 Degrees Celsius and 1 atm', 'DynamicViscosity': '1.80e-5 kg/m/s', 'ElectricalConductivity': '0.00 mS/m', 'Father': 'Gas', 'KinematicViscosity': '1.511e-5 m^2/s', 'MolarMass': '28.965', 'Name': 'Air', 'PrandtlNumber': '0.7', 'RelativePermittivity': '1', 'SpecificHeat': '1010.00 J/kg/K', 'ThermalConductivity': '0.03 W/m/K', 'VolumetricThermalExpansionCoefficient': '0 m^3/m^3/K'}
only the user defined values stay at his value
uwestoehr
Post by uwestoehr »
bernd wrote: Wed Jul 14, 2021 7:55 pm this has not been added lately.
Yes, I see this is also in FC 0.19 and super nasty.
The bug is the conversion from the decimal character:
- Load the card for Air
- click on the thermal conductivity
result: the values was "0.02587 W/m/K". The bug is that this value is interpreted ignoring the dot as being the decimal separator, (by the way, note that I have a German Windows). To FC thinks the value is "2587 W/m/K". Then the FC unit handling converts the unut to W/mm/k and thus the "result" is "2587 W/m/K".
same for the permittivity. The value is interpreted as 10059 but the internal limit is 99.99 so all values above this are reset to 1.
Same for Specific heat: Value is "1.01 kJ/kg/K" -> interpreted as "101 kJ/kg/K", this is then converted to "101000,000 J/kg/K"
bernd
Post by bernd »
Try to use a locale with a "." Still not fixed. ... Ther 1.00059 will be 1.00 and 1.204 will be 1.20.
I gave it a try but the material editor https://github.com/berndhahnebach/FreeC ... lEditor.py is somehow very very difficult to understand ... IMHO. I am just not able to find it in a normal time range ... :evil:
BTW: How about 0.18 ?
bernd
Post by bernd »
same problem on 0.18 ...
0.0257 changes to 0.03
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
BTW no problem with decimal separator, but since it is swiss locale "." is used.
bernd
Post by bernd »
it works in 0.17 :)
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
bernd
Post by bernd »
