collection of material issues
bernd
Re: collection of material issues
Post by bernd »
uwestoehr wrote: Mon Mar 22, 2021 12:45 am Here is the material card file I try to load: Graphite.txt
- download the file
- start FreeCAD
-adapt the code to your location
- run the code
f = open("C:/Users/BHA/Desktop/Graphite.txt", encoding="utf8")
for line in f:
    print(line)
>>> for line in f:
...     print(line)
  File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx_Py3Qt5\bin\lib\codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf6 in position 20: invalid start byte
AFAIKS the problem ist just the file is no utf-8 but ANSI instead.
uwestoehr
Post by uwestoehr »
bernd wrote: Mon Mar 22, 2021 4:47 pm AFAIKS the problem is just the file is no utf-8 but ANSI instead.
Yes. But I created the file using the material card editor and then saved it from there. So there is something wrong in the material editor or the saving routine.
You can reproduce this by creating a new card and using e.g. the text "Björn Überbächle" as author. Save this card, then load this card in a new material.
Besides this, we have another encoding bug: existing material cards like e.g. the PET-generic and when I load this, I see in the author field not the name that is actually in the card.
bernd
Post by bernd »
uwestoehr wrote: Mon Mar 22, 2021 6:58 pm ... But I created the file using the material card editor and then saved it from there. So there is something wrong in the material editor or the saving routine ...
confirmed
uwestoehr
Post by uwestoehr »
For information, other users start to suffer from the Unicode issue in material cards as well:
https://forum.freecadweb.org/viewtopic.php?f=3&t=58892
bernd
Post by bernd »
only happens on windows for me and only happens if there are special character. If there is no special character the file is saved on Windows with UTF-8 as well.
On Linux the mat card is saved with UTF-8 in any case. I will try to have a look ...
bernd
Post by bernd »
uwestoehr
Post by uwestoehr »
bernd wrote: Tue Jul 13, 2021 3:57 pm git commit 9a564dd906f
Many thanks for having a look. I took today's master and recompiled.
The problem persists:
- open the material card editor
- input as card name "Östrogen"
- input as Author And License "Björn Überbächle"
- save the material card as Östrogen.FCMat
Here is the result I get:
Östrogen.zip
zipped FCMat file
(461 Bytes) Downloaded 50 times
Now create a new simulation, add there a material and use the material editor to load the just created material card.
result: the author is lost:
bernd
Post by bernd »
damn I added a regression ...
- start FreeCAD
- switch to FEM
- start the material editor (icon with 3 yellow balls)
- choose whatever material from existent cards
- no property at all is shown ... :o
bernd
Post by bernd »
uwestoehr
Post by uwestoehr »
bernd wrote: Wed Jul 14, 2021 2:09 pm git commit cfcf8df4cee1
many thanks! This fixed 2 issues. :D
I updated the list of known material card bugs:
https://forum.freecadweb.org/viewtopic. ... 66#p489666
If you could have a look at bug 8 and 9, that would be very kind. ;)
