Done. Kind soul welcome to check.
https://wiki.freecadweb.org/FEM_MeshClear
Documentation for FEM_MeshClear
Re: Documentation for FEM_MeshClear
Description ok.RatonLaveur wrote: ↑Thu Apr 01, 2021 2:40 pm Done. Kind soul welcome to check.
Maybe you should add the "the right click option".
Means: select mesh in model tree, right-click opens dialog, then use "clear mesh" option.
Thats how I use this function.
Done. Thank you so much for your input.
EDIT: Actually even better, my initial procedure does not exist in FreeCAD! apparently your way is THE way.
FYI:
It does not delete the mesh from FreeCAD. It reiniitialize the mesh from the FreeCAD FEM mesh object. The mesh still exists but does not have any vertices, edges, faces or elements. You can test in the property view or if you show the mesh properties. It does not say the mesh does not exists because the mesh is there, it is just empty. I adapted the documentation in this regard.
BTW: great job all this documentation. This will help FEM a lot!
