Documentation for FEM_MaterialMechanicalNonlinear
jnxd
Re: Documentation for FEM_MaterialMechanicalNonlinear
Post by jnxd »
bernd wrote: Tue Sep 14, 2021 12:40 pm
What else freecad property types do we have? a dictionary. This could work too.
Two lists, one for the stress and one for the strain, but this is easy to make errors too.
Dictionary is probably the best bet for now, if such a property exists. Might need to consider if there always is a function style relationship. Also, what if someone wants, say, anisotropy?
I would say getting this data structure right the first time would avoid confusion. Once that is done, we can see how this data can be translated for different solvers.
For the other nonlinearities, I believe it is best to make a ConstitutiveRelation class, and rename the current MaterialNonLinear to Simple hardening or some such. Other relations can have their own classes and use the different parameters as necessary.
jnxd
Post by jnxd »
bernd wrote: Tue Sep 14, 2021 12:39 pm
jnxd wrote: Tue Sep 14, 2021 11:39 am
bernd wrote: Tue Sep 14, 2021 8:03 am https://github.com/FreeCAD/FreeCAD/pull ... a2d16bR152
data structure ...
[ stress yield point 1, strain yield point 12, stress yield point 2, strain yield point 2, stress yield point 3, strain yield point 3, ... ]
I am not 100 % convinced if we should go for such a data structure?
This is even more important since we do not have a task panel to edit the data.
I'm 100% sure we should NOT be going for this.
but it is used in your PR ... https://github.com/FreeCAD/FreeCAD/pull ... a2d16bR152
The structure is different. It is ["sigma_1, eps_1", ...] instead of the [sigma_1, eps_1,...] you mentioned.
bernd
Post by bernd »
jnxd wrote: Tue Sep 14, 2021 4:06 pm For the other nonlinearities, I believe it is best to make a ConstitutiveRelation class, and rename the current MaterialNonLinear to Simple hardening or some such. Other relations can have their own classes and use the different parameters as necessary.
It is what I had in mind too. As soon as we have more than one nonlinear model we could rename this object according to the law it is based on, like simple hardening.
bernd
Post by bernd »
jnxd wrote: Tue Sep 14, 2021 4:53 pm
data structure ...
ahh you use the string approach I introduced an put them all in the list. It is not smart either but this would work. It even is what we had all the time. Than this would be ok for now and we could switch to something smarter later on.
jnxd
Post by jnxd »
bernd wrote: Tue Sep 14, 2021 6:43 pm
I suppose. I think I'll leave it at that then...
bernd
Post by bernd »
ok
bernd
Post by bernd »
NewJoker
Post by NewJoker »
Great news! This functionality can be really useful.
Nanayaw
Post by Nanayaw »
Hello Bernd
great if its works, at what version is it implemented then I like to try
Thanks and Greeting
Nanayaw
bernd
Post by bernd »
pull latest master and compile yourself or get weekly build on sunday from freecad weekly repo
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
