Documentation for FEM_MaterialMechanicalNonlinear
Lets give FEM_MaterialMechanicalNonlinear some as well?
Re: Documentation for FEM_MaterialMechanicalNonlinear
Bump
I can add some description but I'm not sure why there are 3 yield points to be defined. Usually we specify either 1 point (perfect plasticity), 2 points (hardening) or several points (multilinear model). This feature should be modified to allow the users to define as many yield points as they want. Unless I just missed the possibility to add more than 3 points there.
Hello NewJoker
it is possible but at the moment only as a work around see like
https://forum.freecadweb.org/viewtopic.php?f=18&t=53960
Greetings
Nanayaw
Greetings
Nanayaw
It shouldn't be difficult to resolve this limitation by adding the possibility to define more yield points. There was a discussion about adding a feature request to BugTracker here: https://forum.freecadweb.org/viewtopic.php?f=18&t=51756
but it seems that it still hasn't been done. To begin with, I can add a ticket for this if you don't mind.
feel free to open a ticket
Thanks, I just added it: https://tracker.freecadweb.org/view.php?id=4720
Now I will write some description about this feature (in its current state) for wiki page.
Hello New Joker and Kunda
I'm happy that the case of the yield points moving forward it is in my eyes a very important thing for FEM analysis
Thanks and Greetings
Nanayaw
Nanayaw
I just added the description of FEM MaterialMechanicalNonlinear
you are totally right ... There is a simple reason ... I needed only two points and I did not want to spent the time to code a task panel. I needed a fast working solution for a real project, thus I made this hack with two strings a yield points. The real implementation just never happened.
Go for it, if you would like to. We need a data model to save as many yield points as needed and some task panel to edit them.
I will help when there are any questions.
