FEA of a 3D-Printed Part
Hello to all female and male readers,
I´m a student from Germany and i am writing my thesis about simulation of 3D-printed parts produced via FDM.
I would like to simulate a part which i sliced with Prusaslicer.
I got an .obj file, but it isn´t a solid. Repairing didn´t worked, it has a huge amount of open contour.
Also i got an G-code file. My idea is to use the G-code, define the layerheigt and the diameter and shape of the deposited filament, and use a macro or something else to extrude this shape along the path given by the G-code. I thought i would get by this way a solid, which i maybe fuse with boolean operations. This solid i would like to simulate and compare the results with an testcase.
My Part is is the testspecimen ISO 527-2 Type 1A. I want to use different infills, such as a honeycomb and diffent percentual grades of an infill.
So manual design is not an option for me.
Are any macros or basebuilds for FreeCAD existing yet? Is my idea makeable in FreeCad?
Of course i can give you an example of the Basepart, obj. file and the G-code.
For usage in the macro i will edit the G-code by leaving out any non necessary part of the Code.
I want to excuse for my bad writing.
Thank you for every answer.
Have a nice day
Nic
Have a nice day
Nic
Re: FEA of a 3D-Printed Part
Mod edit: Moved to FEM subforum (left a shadow topic in Developer subforum)
I can remember i have seen something about 3D printing and heat analysis. My head said it has something to do with Ansys.
But i don't know how they did the 3d print shapes how that was created. At current state i would say FC isn't able to do that kind of advanced mesh / shape generation. Second point is that i believe directly that if FC was able to do something similar FC becomes really slow since FC don't have anything related to optimisation of graphical representation!
I would say if it your PHD then you have probably enough time to program so that shape generation of G code is possible. if it is a master thesis i think you have to try somewhere else.
You say repairing did not work, did you look at MeshLab https://www.meshlab.netKlemmkeil wrote: ↑Sun Apr 04, 2021 11:31 am Hello to all female and male readers,
Have a nice day
Nic
You might also research Gmsh and Tetgen.
yes i allready looked at meshlab.
I will give it a try tomorrow.
I thought by using a macro, i could also extrude the real form of the filament.
This shape i will investigate in microscopie and will edit it.
I would say yes. Here is a testcase. Maybe you can use this as a starting point.
Fixing broken obj/stl-files is time consuming.
You can re-run the analysis by yourself:
open file in FC
doubleclick on analysis in modeltree, FEM workbench activates
doubleclick on FEMMesh in modeltree, press "apply" for remeshing
doubleclick on solver in tree, write inp-file and run analysis.
Meshing is fast, calculation < 1 min.
Hope that helps.
Frohe Ostern (Happy Eastern)
Thomas
What about designing the 3d model in a way it would look like after the slicer prepared it for printing? Amount of perimeters, infill and so on? Would that work for you?
Regards / Viele Grüße
Max
Max
Thank you for your Answer.
It's a good Example for a Simulation.
thschrader wrote: ↑Mon Apr 05, 2021 9:08 amI would say yes. Here is a testcase. Maybe you can use this as a starting point.
open file in FC
Hope that helps.
Thomas
test_iso.FCStd
Designing it, would be usefull. But i think it would be really timeconsuming or not exact. So i would get unwanted divergences between the simulation and the testcase.
I'm currently working on a macro, which interpretates my g-code. I'm a newbie in phyton, but i hope to get it working.
When i get good results, i will post the results and the macro in this thread.
To answer that, we would need a picture or something like that
Max
Max
