[solved] FreeCAD creates only surface mesh, no volume mesh
baudri
Post by baudri »
I am struggling with FEM for a combination of three parts with different material. I tried to do it the same way as in https://www.youtube.com/watch?v=T-ggqH3tXHs
I created a compound via boolean fragments and compound filter.
Solids: 3
CompSolids: 1
Compounds: 0
When I try to mesh it, I get only a surface mesh (both with Netgen and gmsh). I think, once it worked, but I can not repeat ist.
I already replaced the screws by simple solids without any success. I also could not find any solution in the forum. Any hint would be highly appreciated.
The attached file has a low resolution grid for low file size.
I am using:
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Adapter_Sitz_Drehkonsole_FEM_v02.FCStd
(343.34 KiB) Downloaded 41 times
UR_
Re: FreeCAD creates only surface mesh, no volume mesh
Post by UR_ »
baudri wrote: Sun Apr 18, 2021 7:34 pm ... I get only a surface mesh ...
Can't confirm.
========================== Dump contents of mesh ==========================
1) Total number of nodes: 60084
2) Total number of edges: 798
3) Total number of faces: 8804
4) Total number of polygons: 0
5) Total number of volumes: 39138
6) Total number of polyhedrons: 0
7) Total number of linear edges: 0
8) Total number of linear faces: 0
9) Total number of linear volumes: 0
10) Total number of quadratic edges: 798
11) Total number of quadratic faces: 8804
11.1) Number of quadratic triangles: 8804
11.2) Number of quadratic quadrangles: 0
12) Total number of quadratic volumes: 39138
12.1) Number of quadratic hexahedrons: 0
12.2) Number of quadratic tetrahedrons: 39138
12.3) Number of quadratic prisms: 0
12.4) Number of quadratic pyramids: 0
version (conda):
OS: Windows 10 (10.0)
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.5.1
RatonLaveur
Post by RatonLaveur »
Same here, check your mesh in ParaView if you need to ve reassured.
baudri
Post by baudri »
Thanks. My first mesh also had volumes. Then, when I changed parameters to get a finer mesh, I never got volumes anymore.
When I look at the data of the FEM mesh, I get the following:
I deleted the mesh and again created it and now there are volumes. Did the same for at least three times before writing this post.I do not know what I did wrong the last time. Sorry for the confusion.
