This is my first post on this forum.
I tried to do a simple FEM analysis on a pipeline structure.
->Applied constraints on all 4 legs.
->Applied force on of the top corner edge
-> system shows CALCULIX Finished with error 16.
What is the reason for this error.
Am I missing something basic ?
I could not find about this error in in forum. How can I overcome such issue. I have attached the Assembly File & error Screenshot.
Please help me resolve the error.
Thanks & Regards
Ankit
Fem : Calculix Error 16
- FEMcommandsScreenshot.jpeg (108.67 KiB) Viewed 2133 times
- ErrorScreenshot.jpeg (113.58 KiB) Viewed 2133 times
- Structure4set.FCStd
- (104.85 KiB) Downloaded 38 times
Re: Fem : Calculix Error 16
Are you able to use the FreeCAD FEM standard cantilever example from FEM utilities example gui?
Would you post your FreeCAD version information?
There is no FEM analysis in your file? It is just geometry.
Hi Bernd,
I am using Freecad with following Version :
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Please check the following link for the fem file attached ( could not attach it due to size restrictions) : https://drive.google.com/file/d/1BAqKvK ... sp=sharing
Are you able to use the FreeCAD FEM standard cantilever example from FEM utilities example gui?. Yes I was able to do cantilever simulation in my system .
Please guide further.
Thanks
Ankit Shukla
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks
Ankit Shukla
If you clear the mesh (clear it do not delete the object) the file has just about 118 kB and it could be attached easily. Since I have ASM3 not installaed, the file I have saved migth miss something ...ankitshukla wrote: ↑Thu Jun 10, 2021 9:57 am Please check the following link for the fem file attached ( could not attach it due to size restrictions) : https://drive.google.com/file/d/1BAqKvK ... sp=sharing
Thanks for showing the way to reduce the file size. I have attached the file after clearing the mesh.
Please let me know the steps further.
- Structure4setFEM2.FCStd
- (108.44 KiB) Downloaded 29 times
Also I wanted to mention my system has 4 gb RAM. Just in case if that could hinder the performance and result in error.
Hi
Can some please run it in your system & let me know if such error occurs in your system.
Thanks
Ankit Shukla
Thanks
Ankit Shukla
Hello!
First: Please delete all unneeded elements. I get dozens off errors because i have not addons installed and also have not all of your subparts.
Second: You have not cleared the mesh right. Keep the object, rightclick on the object and press Clear FEM mesh. This is imported to get all your settings. When i mesh your object with autosettings i get a very bad mesh.
Greetings
user1234
Greetings
user1234
