How do I analyze "Assembly 4" and "Dual Material"?
xsuper9988
Post by xsuper9988 »
I designed a simple gantry structure for FEM testing
I have simplified the structure
Keep only the main structure
The square iron tube is filled with concrete inside
Please provide ideas
thank you very much
My File:
https://drive.google.com/file/d/13nKbgc ... sp=sharing
bernd
Re: How do I analyze "Assembly 4" and "Dual Material"?
Post by bernd »
which parts of the structure would youlike to analyze?
thschrader
Post by thschrader »
xsuper9988 wrote: Sat Jun 12, 2021 12:05 pm The square iron tube is filled with concrete inside
Forget the concrete :)
Enhance wall thickness and add endplates at the beam.
After doing a bit of defeaturing (eliminate fillets/holes) and adding to beams at the top
to simulate excentric loading the results are at 5 kN z-load:
stresses lower than 30 MPa, max deflection 0,14 mm.
The structure is very stiff.
My FC-file with cleared mesh:
ASM_FEM_th.FCStd
(49.7 KiB) Downloaded 26 times
xsuper9988
bernd wrote: Sat Jun 12, 2021 1:41 pm which parts of the structure would youlike to analyze?
The current parts are the main load-bearing structure
So currently I want to analyze
1.
Analysis on X-axis linear module
2.
Analysis on Z-axis linear module
2.
Analyze on the tool
From the structure point of view, I should analyze these three points. Isn't it right?
xsuper9988
thschrader wrote: Sat Jun 12, 2021 4:20 pm
ASM_FEM_th.FCStd
Your analysis is for the rigidity of the gantry
Although my final structure is not like this
But I can refer to your analysis method
In addition...
Can you assist in providing an analysis with concrete?
thank you for your sharing
xsuper9988
bernd
Post by bernd »
The problem will be the mesh on such geometrical complicated structures. If you get it meshed you can analyse it. Thus try to mesh what you would like to analyse. Check the mesh. If the solver refuses to analyze it, you need to get rid of geometrical problems. Use the Part --> geometry check first. If this fails it is common the mesher has problems too.
Would be cool if you would be able to mesh such a structure inside FreeCAD. We would be on the same stair step as ANSYS 8-)
Keep us informed with pics.
thschrader
xsuper9988 wrote: Tue Jun 15, 2021 5:53 am In addition...
Steel hollow beam with concrete filling.
Be patient, inp writing needs 4 min.
See stress-plot, the effect of the concrete is nearly zero.
File with cleared mesh:
beam_concrete.FCStd
(18.44 KiB) Downloaded 29 times
Done with:
OS: Windows 10 Version 1909
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
xsuper9988
bernd wrote: Thu Jun 17, 2021 6:58 am The problem will be the mesh on such geometrical complicated structures. If you get it meshed you can analyse it. Thus try to mesh what you would like to analyse. Check the mesh. If the solver refuses to analyze it, you need to get rid of geometrical problems. Use the Part --> geometry check first. If this fails it is common the mesher has problems too.
Yeah, so...
Do you know any other software that can analyze machinery?
Can you give me a list?
For analysis in FREECAD
Do you have other suggestions?
Thank you very much
xsuper9988
thschrader wrote: Thu Jun 17, 2021 9:46 am
beam_concrete.FCStd
Done with:
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I will test again
Thank you very much
