Hinges between plates/shells
Re: Hinges between plates/shells
Yes. I want avoid github itself as a can. But at first my local branch should work anyway. Then make the diffs.
Thanks!
Greetings
user1234
Thanks!
Greetings
user1234
http://www.feacluster.com/CalculiX/ccx_ ... de278.html
This Bernd provided link says "A *MPC card automatically triggers the NLGEOM parameter, i.e. a geometrically nonlinear calculation is performed, except if the MPC is a mean rotation MPC."
For mean rotation MPC, you could see example here http://www.feacluster.com/CalculiX/ccx_ ... de353.html
MPC is equivalent to this EQUATION. For Nastran95: G1=point 1, C1=1 (x displacement), A1=1.0fandaL wrote: ↑Tue Jul 13, 2021 11:01 amCode: Select all
** BINDING DOF OF DUPLICATED NODES ** NODES 1 AND 40 *EQUATION 2 1, 1, 1, 40, 1, -1
G2=point 40,C2=1 (x displacement),A2= - 1.0
Here is a working version with MPC as hinge for Mystran.
Here is a working version with RBE2 as hinge for Mystran. The result is 8.5, same as the commercial one.
Does Calculix has RBE2? Nastran95 is CRBE2.
Hi John, thanks for your work.
There is a question in the german forum about Frame3DD.
Maybe you can answer Lauries question. Dont hesitate to write in english.
https://forum.freecadweb.org/viewtopic. ... 9&start=50
Is there anyone already pursuing this?
Got a window of opportunity and was thinking of trying to give it a serious go.
Tough I'm been poking around the code and it seems like a more complicated task than I initially thought. But you can't blame a guy for trying.
I have uploaded a working version with MPC as hinge for Mystran.twangrt wrote: ↑Mon Jul 26, 2021 9:26 am Is there anyone already pursuing this?
For Calculix, you need to understand the 'mean rotation MPC' I mentioned.
The only working solution for Calculix we have found so far is by changing the original mesh, which is not something I am happy with ... https://forum.freecadweb.org/viewtopic. ... 20#p516277
It would be cool if we would found something without changing the mesh and without triggering nonlinear analysis.
