Hinges between plates/shells
bernd
Re: Hinges between plates/shells
Post by bernd »
user1234 wrote: Sun Jul 11, 2021 6:51 pm To be honest, i do not get that out of the description from the first post. But yes, that in FEM will be pretty hard.
once we know how to define the hinge in calculix it is just a diligent but routine piece of work mostly done in Python. Furthermore we will need some Name, some Icon a wiki page ... all that kind of stuff ... But step by step. As said first the example. fandaL started to provide somethin.
user1234
Post by user1234 »
I mean i have overread that he need a hinge in the middle of the plate.
bernd wrote: Sun Jul 11, 2021 8:21 pmonce we know how to define the hinge in calculix it is just a diligent but routine piece of work mostly done in Python.
I want to try it, since i want to help more. But this will take a while to understand all. Must crawling through the sources.
Greetings
user1234
bernd
Post by bernd »
user1234 wrote: Sun Jul 11, 2021 8:42 pm
last FEM object we added was this one ... https://github.com/FreeCAD/FreeCAD/comp ... 282db7c8c6
thschrader
Post by thschrader »
bernd wrote: Sun Jul 11, 2021 6:15 pm Totally correct if you would like to have a hinged support, but Thomas would like to set the hinge between two faces ore between two beams and not on a support.
Yes, I mean hinges between plates, not at he support (which is implemented in FC-FEM).
BTW: perfect :)
cad1234
Post by cad1234 »
Would be great, if the hinged-feature could be integrated in FC-FEM.
Would be very helpfull not only for concrete or steel structures but also for wooden structures (due to the different material properties, depending on the fiber direction)...I think..
found this in ccx manual (2.16):
“For an internal hinge between 1D or 2D elements the nodes must be doubled and connected with MPC’s. The connection between 3D elements and all other elements (1D or 2D) is always hinged”
no experience / not enough knowledge how to handle this :-(
twangrt
Post by twangrt »
cad1234 wrote: Mon Jul 12, 2021 9:32 am found this in the ccx manual (2.16)
You beat me to it, was searching around the manual for exactly that. :D
I'm just wanted to add the MPC-card explanation as well.
6.7.2 Multiple point constraints (MPC)
Multiple point constraints establish a relationship between degrees of freedom in
one or more nodes. In this section, only linear relationships are considered (for
nonlinear relations look at the keyword *MPC and section 9.7).They must be
defined with the keyword *EQUATION before the first step.
I think this is an interesting topic, been thinking about ways of improving the 1D/2D support between Calculix and FreeCAD.
bernd
Post by bernd »
twangrt wrote: Mon Jul 12, 2021 9:41 am I think this is an interesting topic, been thinking about ways of improving the 1D/2D support between Calculix and FreeCAD.
structural engineer ;)
bernd
Post by bernd »
I tried to make a simplified model ... This is much simpler to play with. But I may made a misstake (because I was to fast in clicking ... ) ... The deformation is quite large (35 cm) ... May be some other could have a look as well ...
concrete_plate_bernd.FCStd
(661.91 KiB) Downloaded 43 times
balrobs
Post by balrobs »
bernd wrote: Mon Jul 12, 2021 1:05 pm I tried to make a simplified model ... This is much simpler to play with. But I may made a misstake (because I was to fast in clicking ... ) ... The deformation is quite large (35 cm) ... May be some other could have a look as well ...
Hi Bernd,
your result seems OK! I get 36cm with my commercial software!
Large deformation are due to large forces f=60000 kN/(6m*2m)=5000 kN/m2
Cheers
Edit:
PS: in the meantime I learned to compile Freecad on Linux so maybe I can help within this topic by doing some test work :D
thschrader
bernd wrote: Mon Jul 12, 2021 1:05 pm deformation is quite large (35 cm) ... May be some other could have a look as well ...
Load were far too high.
Did some modifications and comparison with my commercial tool.
concrete_plate_ts.FCStd
(12.33 KiB) Downloaded 44 times
