Damn ... Than not 10 mm by 10 mm and 0.3 mm thick. But 10 inches by 10 inches and 0.3 inches thick ...aerospaceweeb wrote: ↑Sun Jul 18, 2021 8:42 pmNastran, Steve, and I are all American, so the units you'll see in our bdfs is usually inches and pounds, except for modal solutions, then american units REALLY start to get annoying.bernd wrote: ↑Sun Jul 18, 2021 8:34 pm ATM I only need to understand the plate one. It is the one I have started with. https://github.com/SteveDoyle2/pyNastra ... dels/plate
- the grid is no problem. I already understood this one.
- thickness is 0.3 mm
- material: Poisons Ratio is 0.3, Young's Modulus is 70'000'000.0 ??? which leads to the question Which unit has the file
- lengths is in mm, how about force and young's modulus?
- For the load ... there is "load", "force" and "pload" ... I have not read these yet ...
- IMHO it is not an edge load because the end points are moving more. I assume it is the same node load on each mesh node on the edge, thus the outer nodes moves more. OK I need to read the card docu ...
bernd
Solver for Mystran
Re: hfcMYSTRAN - a test case
sounds interesting.johnwang wrote: ↑Sun Jul 18, 2021 8:44 pmYou can call pyNastran within FreeCAD.
When I started, I played with pyNastran to read case file. A few models from it which I read are posted in this thread.But the bdf is a little different from Nastran95's inp and Mystran's dat. Instead of learning pyNastran, I started to write my own for hfcMystran and hfcNastran.
Only recently, I began to play with writing case file. I haven't tested pyNastran's writing functions. I am using Fortran. The Hinge. dat and Bridge. dat are two examples.Direct coding, no CAD. But I have an OpenGL program which I can read a case file and show the model. I will add simple sketch tools to connect these two.
I like to do it as simple as possible and to reuse as much as possible. Thus I would like to use pyNastran. From what I have seen so far it is great.
Re: Solver for Mystran
https://github.com/SteveDoyle2/pyNastra ... te.bdf#L60
google says 7E7 pounds/square inch = 482'633.0 MPa What is this plate made from???
MAT1 1 7.+7 .3
I think pyNastran has better support for inp and dat now.
In my impression, it is not really a pre program. You still need CAD and meshing. FreeCad needs works in 2d and 3d shell.
Imagination-iniumbernd wrote: ↑Sun Jul 18, 2021 9:03 pm https://github.com/SteveDoyle2/pyNastra ... te.bdf#L60
google says 7E7 pounds/square inch = 482'633.0 MPa What is this plate made from???Code: Select all
MAT1 1 7.+7 .3
Or maybe tungsten idk
some informations about the plate example ...
- link to orgiginal file
https://github.com/SteveDoyle2/pyNastra ... /plate.bdf
- parse it with pyNastran to have something to compare with
- create the same model with pyNastran
from pyNastran.bdf.bdf import BDF
model = BDF()
model.read_bdf("plate.bdf")
model.write_bdf("plate_pyNastran_frombdf.bdf")
from pyNastran.bdf.bdf import CaseControlDeck
model = BDF()
# executive control
model.sol = 101
# params
model.add_param(key="POST", values=-1)
model.add_param(key="PRTMAXIM", values="YES")
# materials
E = 7.e7
G = None
nu = 0.3
mat = model.add_mat1(1, E, G, nu)
# nodes
model.add_grid(1, [0., 0., 0.])
model.add_grid(2, [2., 0., 0.])
model.add_grid(3, [4., 0., 0.])
model.add_grid(4, [6., 0., 0.])
model.add_grid(5, [8., 0., 0.])
model.add_grid(6, [10., 0., 0.])
model.add_grid(7, [0., 2., 0.])
model.add_grid(8, [2., 2., 0.])
model.add_grid(9, [4., 2., 0.])
model.add_grid(10, [6., 2., 0.])
model.add_grid(11, [8., 2., 0.])
model.add_grid(12, [10., 2., 0.])
model.add_grid(13, [0., 4., 0.])
model.add_grid(14, [2., 4., 0.])
model.add_grid(15, [4., 4., 0.])
model.add_grid(16, [6., 4., 0.])
model.add_grid(17, [8., 4., 0.])
model.add_grid(18, [10., 4., 0.])
model.add_grid(19, [0., 6., 0.])
model.add_grid(20, [2., 6., 0.])
model.add_grid(21, [4., 6., 0.])
model.add_grid(22, [6., 6., 0.])
model.add_grid(23, [8., 6., 0.])
model.add_grid(24, [10., 6., 0.])
model.add_grid(25, [0., 8., 0.])
model.add_grid(26, [2., 8., 0.])
model.add_grid(27, [4., 8., 0.])
model.add_grid(28, [6., 8., 0.])
model.add_grid(29, [8., 8., 0.])
model.add_grid(30, [10., 8., 0.])
model.add_grid(31, [0., 10., 0.])
model.add_grid(32, [2., 10., 0.])
model.add_grid(33, [4., 10., 0.])
model.add_grid(34, [6., 10., 0.])
model.add_grid(35, [8., 10., 0.])
model.add_grid(36, [10., 10., 0.])
# elements
model.add_cquad4(1, 1, [1, 2, 8, 7])
model.add_cquad4(2, 1, [2, 3, 9, 8])
model.add_cquad4(3, 1, [3, 4, 10, 9])
model.add_cquad4(4, 1, [4, 5, 11, 10])
model.add_cquad4(5, 1, [5, 6, 12, 11])
model.add_cquad4(6, 1, [7, 8, 14, 13])
model.add_cquad4(7, 1, [8, 9, 15, 14])
model.add_cquad4(8, 1, [9, 10, 16, 15])
model.add_cquad4(9, 1, [10, 11, 17, 16])
model.add_cquad4(10, 1, [11, 12, 18, 17])
model.add_cquad4(11, 1, [13, 14, 20, 19])
model.add_cquad4(12, 1, [14, 15, 21, 20])
model.add_cquad4(13, 1, [15, 16, 22, 21])
model.add_cquad4(14, 1, [16, 17, 23, 22])
model.add_cquad4(15, 1, [17, 18, 24, 23])
model.add_cquad4(16, 1, [19, 20, 26, 25])
model.add_cquad4(17, 1, [20, 21, 27, 26])
model.add_cquad4(18, 1, [21, 22, 28, 27])
model.add_cquad4(19, 1, [22, 23, 29, 28])
model.add_cquad4(20, 1, [23, 24, 30, 29])
model.add_cquad4(21, 1, [25, 26, 32, 31])
model.add_cquad4(22, 1, [26, 27, 33, 32])
model.add_cquad4(23, 1, [27, 28, 34, 33])
model.add_cquad4(24, 1, [28, 29, 35, 34])
model.add_cquad4(25, 1, [29, 30, 36, 35])
# properties
model.add_pshell(1, mid1=1, t=0.3, mid2=1, mid3=1)
# load cards
model.add_load(sid=2, scale=1.0, scale_factors=1.0, load_ids=1)
model.add_load(sid=3, scale=1.0, scale_factors=1.0, load_ids=10)
model.add_load(sid=4, scale=1.0, scale_factors=5.0, load_ids=10)
model.add_load(sid=5, scale=7.0, scale_factors=1.0, load_ids=10)
model.add_load(sid=6, scale=7.0, scale_factors=5.0, load_ids=10)
model.add_load(sid=7, scale=1.0, scale_factors=[1.0, 1.0], load_ids=[1, 11])
# force card (node load)
model.add_force(sid=1, node=6, mag=100, xyz=(1.0, 0.0, 0.0))
model.add_force(sid=1, node=12, mag=100, xyz=(1.0, 0.0, 0.0))
model.add_force(sid=1, node=18, mag=100, xyz=(1.0, 0.0, 0.0))
model.add_force(sid=1, node=24, mag=100, xyz=(1.0, 0.0, 0.0))
model.add_force(sid=1, node=30, mag=100, xyz=(1.0, 0.0, 0.0))
model.add_force(sid=1, node=36, mag=100, xyz=(1.0, 0.0, 0.0))
# pload4 card (element pressure on quad4)
pl_ele_ids = [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25]
model.add_pload4(sid=10, eids=pl_ele_ids, pressures=[3.0, 3.0, 3.0, 3.0], cid=None)
model.add_pload4(sid=11, eids=[1], pressures=[3.0, 3.0, 3.0, 3.0], cid=None)
# card spcadd
model.add_spcadd(conid=2, sets=[1],)
# fixed
fixed_nodes = [1, 7, 13, 19, 25, 31]
model.add_spc1(conid=1, components="123456", nodes=fixed_nodes)
# case control
cc = CaseControlDeck([
"ECHO = NONE",
"TITLE = pyNastran plate example for Mystran",
"SUBCASE 1",
" SUBTITLE = Default",
" LOAD = 2",
" SPC = 2",
" SPCFORCES(SORT1,REAL) = ALL",
" STRESS(SORT1,REAL,VONMISES,BILIN) = ALL",
" DISPLACEMENT(SORT1,REAL) = ALL",
model.case_control_deck = cc
# model.validate() # creates an error
model.write_bdf("plate_pyNastran_Bernd.bdf", enddata=True)
for reference the files ...
If I run the bdfs in Mystran I get the following deformation ...
But how about the pload4 cards? They are some pressure. Where is the deformation from them? Since I can not view the results in any other software I do not know it it is the result reader or if the pload4 are not analysed. May be I do not really understand what the pload cards should do in this example. Anyone does know what the pload4 cards should do in this example?
Direct Download Link - For End Users (Compiled Windows EXE, Documentation, Test Runs, Other Files)
https://www.mystran.com/forums/showthread.php?tid=39
PLOAD4 is specifying Pressure value at up to 4 grid locations.
You can define many loads(pressure or force), but only those SID number is equal to that specified in the Case Control Deck (LOAD = SID) will take effect. You can build more load cases with different LOAD = SID. For example:
Load subcase 1, you set LOAD = 100, calculate response under all loads with SID=100 .
Load subcase 2, you set LOAD = 200, calculate response under all loads with SID=200 .
I missed this one ... That makes totally sense ...
Still I am not able to get any deformation from the pload entries in that plate file. But nevermind ATM I am only interested in the force entries and they work very well.
