Change LOAD = 11, re-run.
When check result, Change Slider Max to 10000.
YEAH ... I tried to input the load case lines (load) int the subcase but I did not try to directly input the pload4 id. It will take some time to get into all this ...
very helpful ...aerospaceweeb wrote: ↑Sun Jul 18, 2021 7:59 pm ...
Here's a pretty good online NX nastran documentation.
http://www2.me.rochester.edu/courses/ME ... 6:id507676
FORCE,1,101,0,100.0,0.0,0.0,1.0
FORCE,1,102,0,100.0,0.0,0.0,1.0
FORCE,1,103,0,100.0,0.0,0.0,1.0
FORCE,1,104,0,100.0,0.0,0.0,1.0
FORCE,1,105,0,100.0,0.0,0.0,1.0
*ERROR 1820: THERE MUST BE AT LEAST 1 ELEMENT IN THE BULK DATA. HOWEVER, NELE = 0
Thanks for the hint. I found it too. cheers berndfandaL wrote: ↑Thu Jul 22, 2021 8:22 am Official Mystran 12.1 documentation
https://www.mystran.com/forums/showthread.php?tid=39
does not know CTRIA6. There are only CTRIA3 and CQUAD4 (and CTRIA3K and CQUAD4K for thin variants without transverse shear deformation).
*ERROR 1928: ELEMENT 149, TYPE TETRA10 , HAS JACOBIAN LESS THAN OR EQUAL TO ZERO ( = -7.3E+08). BAD GEOMETRY
$-------ID------CP------X1------X2------X3------CD------PS------9-------+-------
GRID 1 0.00E+0030.000000.00E+00
Yours:
GRID 1 8000. 1000. 0.
CTETRA 149 1 40 19 10 20 168 106
196 171 66 107
model.add_grid(1, [8000.0, 1000.0, 0.0])
model.add_ctetra(147, 1, [23, 12, 22, 42, 110, 122, 68, 174, 192, 184])
