Non Linear Material
Non Linear Material
Hello everyone,
actually i'm building some non linear simulations.
In the last days i got some mechanical data from some tests in the laboratory, so i would like to implement it in my simulation.
The simulation works, it didn't made any validation, but i looked into the results and unter PEEQ there is just zero.
I thought maybe my simulation is not correct. Am i rigth?
If yes, what did i have done wrong?
I changed the input-file according to the picture by hand.
Mesh is generated extern in Gmesh
Greetings Nic
Greetings Nic
- input.PNG (36.94 KiB) Viewed 1746 times
Re: Non Linear Material
I cannot upload my model because of a http-error
i cleared mesh and the size schould be ok.
PEEQ stands for equivalent plastic strain. For linear material PEEQ will be zero in any case. You will get PEEQ strain only if you use non linear material. There is a non linear material example in the FreeCAD FEM examples GUI. This will have PEEQ strain.
cheers bernd
cheers bernd
BTW, which FreeCAD version do you use? For FreeCAD FEM you should use 0.20 dev version.
cheers bernd
cheers bernd
I downloaded FreeCAD 0.20 and run my simulation.
Same result, i think the PEEQ must be bigger than zero, because the stress is so big, i must have plastic strain.
- Histogramm.PNG (24.64 KiB) Viewed 1626 times
In real world yes, but not in a FEM analysis. If you do not tell the FEM solver the material should stop to use a linear curve for stress strain it will continue to increase your stress to infinity. In FEM this is normal behaviour in singularity points.
https://www.comsol.com/blogs/singularit ... red-spots/
Do you have added a non linear material to your analysis or not? I may missunderstand something ... If you have added a nonlinear material there should be PEEQ stress ...
Have you played with the non linear example for GUI examples? Does this work for you? HAve you changed parameter in this example? Does it still work?
My Part seems to big for uploading, if somebody wants it, i could provide by another way.
Just give me some advice which way you prefer.
- Part.PNG (124.92 KiB) Viewed 1615 times
- upload.FCStd
- (6.79 KiB) Downloaded 43 times
the file you uploaded misses the mesh! You should not delete the mesh object but clear the mesh from the mesh object (right click on mesh object--> clear).
In this file is only a cube ...
Hi Bernd,
i used a non linear material an edited it in the input-file, like shown in the picture above.
Was that the rigth way?
