Speeding up my simulation
Hello everyone,
i would like to increase the speed of my simulation by utilizing the maximum ressources of my computer.
I got the AMD Ryzen 9 5950X as CPU and 128GB of RAM, so there are much ressorces left unused.
Which changes in properties and additional software are needed to get the best performance with FreeCAD?
I'm using FreeCAD 0.20, downloaded it yesterday
Greetings Nic
Greetings Nic
Re: Speeding up my simulation
What exactly would you like to speed up?
- solving FEM in FreeCAD
- meshing for FEM in FreeCAD
- workflow inside FreeCAD
Please always copy/paste your full About info, especially when it comes to FEM since it is constantly under development.
Here my about:
OS: Windows 10 Version 2009
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I would like to speed up FEM-solving.
Meshing is often linked with problems( my experienc in older Version)
Most of the time i mesh in Gmsh or Netgen directly and import it.
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Speeding up Calculix solving should be easy. Calculix supports multiprozessor. There is even a pref in FreeCAD FEM where you can set the number of cores. But for this you have to set the solver to spooles. Give it a try. Would be cool if you could reoport back if it had worked for you.
cheers bernd
cheers bernd
You mean this settings?
I used it allready over a longer time.
But it uses maybe up to 3% of my CPU.
Most of the Time i run 6 or 7 simulation at the same Time to get a good usage.
Spooles is the fastet solver ?
- Settings.PNG (8.26 KiB) Viewed 2001 times
I have been having some issues on linux and macOS, that the setting for multithreading in preferences doesn't work.
Look at the output from the console after solving:
Here is a fix to get around the problem:
https://forum.freecadweb.org/viewtopic. ... 3&start=10
Using up to X cpu(s) for spooles.
import multiprocessing
import os
cpu_cores = multiprocessing.cpu_count() # this finds number of your CPUs and use them all
os.putenv('OMP_NUM_THREADS', str(cpu_cores))
brilliant, btw - assuming that it works - would it not be a permanent fix if that was included in source?
The macro worked for me.
Now I'm using my whole CPU.
- CPU USE.PNG (29.13 KiB) Viewed 1921 times
