Request for help meshing and and analysing a part {Solved}
I have run into 4 "jac" errors meshing this part and analysing it. (I don't know what they are to be quite frank)
I am a FEM novice and no doubt I am making an elementary mistake.
Any help pointing out where I am going wrong and pointers in the right direction will be greatly appreciated.
- 65 SHS x 4 x1358 Chord 1500 Grid 18mm Holes(Checked).FCStd
- (261.91 KiB) Downloaded 789 times
Last edited by Laurie Hartley on Tue Feb 01, 2022 2:54 am, edited 1 time in total.
Re: Request for help meshing and and analysing a part
It’s just hard to obtain a sufficient quality solid mesh for this thin-walled part. The error that you get means that your mesh has nonpositive jacobians. Try with finer mesh or another mesher (Netgen). If this doesn’t work, consider simplifying this part and using shell elements.
Update: It seems that Gmsh yields correct mesh and the analysis runs to completion when max element size is set to 3 or 4.
Have you tried to set second order linear? This helps a lot and you do not need to make a very fine mesh.
https://wiki.freecadweb.org/FEM_MeshGms ... _Jacobians
if you use the run button the non positives are green.if there are only a few a local finer mesh or improving the geometry could be an option as well.
bernd
bernd
Thanks Bernd - I will try this as well as new jokers suggestion above and post the outcomes tomorrow.bernd wrote: ↑Tue Aug 10, 2021 9:53 am Have you tried to set second order linear? This helps a lot and you do not need to make a very fine mesh.
bernd
I tried both methods and was able to get a clean mesh but encountered another problem probably best explained by uploading some screen shots - see below. (No modes found in Frd file)
For New Jokers suggestion I set gmsh "from shape" the maximum node size to 3mm and min to automatic.
For you suggestion bernd I set gmsh "2D" and the shell geometry thickness to 4mm. (not sure if I have interpreted your instructions correctly)
I ran an analysis on another part successfuly so I don't think I have broken FreeCAD.
OS: Debian GNU/Linux 10 (buster) (XFCE/xfce)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
[code]
System: Host: <filter> Kernel: 5.8.0-3-amd64 x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8.0-3-amd64
root=UUID=<filter> ro splash quiet
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
Distro: MX-19.4_ahs_x64 patito feo March 31 2021 base: Debian GNU/Linux 10 (buster)
Machine: Type: Laptop System: LENOVO product: 20NFA00PAU v: ThinkPad E595 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NFA00PAU serial: <filter> UEFI: LENOVO v: R11ET40W (1.20 )
date: 11/17/2020
Battery: ID-1: BAT0 charge: 41.8 Wh condition: 43.9/45.7 Wh (96%) volts: 12.3/11.1
model: Celxpert 5B10W138 type: Li-poly serial: <filter> status: Unknown cycles: 2
CPU: Topology: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108102 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36732
Speed: 1851 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz): 1: 1144
2: 1304 3: 1189 4: 1297 5: 1237 6: 1168 7: 1530 8: 1605
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics: Device-1: AMD Picasso vendor: Lenovo ThinkPad E595 driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:15d8
Display: x11 server: X.Org 1.20.10 driver: amdgpu
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL:
renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.38.0 5.8.0-3-amd64 LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo ThinkPad E595
driver: snd_hda_intel v: kernel bus ID: 05:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo ThinkPad E595 driver: N/A bus ID: 05:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo ThinkPad E595 driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.0-3-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo ThinkPad E595 driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: eth0 state: down mac: <filter>
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A port: 2000 bus ID: 04:00.0
chip ID: 10ec:b822
IF: wlan0 state: up mac: <filter>
Drives: Local Storage: total: 1000.80 GiB used: 209.38 GiB (20.9%)
ID-1: /dev/mmcblk0 model: SD64G size: 58.09 GiB block size: physical: 512 B
logical: 512 B serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L7 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 5M2QEXF7 scheme: GPT
ID-3: /dev/sda type: USB vendor: Seagate model: ST9500325AS size: 465.76 GiB
block size: physical: 512 B logical: 512 B rotation: 5400 rpm serial: <filter>
rev: 0130 scheme: MBR
Partition: ID-1: / raw size: 474.66 GiB size: 466.21 GiB (98.22%) used: 209.38 GiB (44.9%)
fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 2.00 GiB used: 1024 KiB (0.0%) fs: swap
swappiness: 15 (default 60) cache pressure: 100 (default) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 59.2 C mobo: 0.0 C gpu: amdgpu temp: 59 C
Fan Speeds (RPM): cpu: 0
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
1: deb http://deb.debian.org/debian buster-updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/debian.list
1: deb http://deb.debian.org/debian buster main contrib non-free
2: deb http://deb.debian.org/debian-security buster/updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/megasync.list
1: deb https://mega.nz/linux/MEGAsync/Debian_10.0/ ./
Active apt repos in: /etc/apt/sources.list.d/mx.list
1: deb http://mirror.datamossa.io/mxlinux/mx/repo/ buster main non-free
2: deb http://mirror.datamossa.io/mxlinux/mx/repo/ buster ahs
Active apt repos in: /etc/apt/sources.list.d/softmaker.list
1: deb http://shop.softmaker.com/repo/apt wheezy non-free
No active apt repos in: /etc/apt/sources.list.d/various.list
Info: Processes: 271 Uptime: 6h 16m Memory: 13.61 GiB used: 2.55 GiB (18.7%) Init: SysVinit
v: 2.93 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: quick-system-in
running in: quick-system-in inxi: 3.0.36
- No modes found in Frd file_3mm_max_from_shape.png (72.61 KiB) Viewed 42090 times
- No modes found in Frd file_2D_shell_4mm_output_true.png (128.54 KiB) Viewed 42090 times
- No modes found in Frd file_2D_shell_4mm-output_false.png (75.76 KiB) Viewed 42090 times
Here is a sim with 2D-shell elements. I eliminated the fillets in the MSH-profileLaurie Hartley wrote: ↑Tue Aug 10, 2021 11:21 am For you suggestion bernd I set gmsh "2D" and the shell geometry thickness to 4mm.
with the defeaturing-wb. With fillets I get a weird mesh.
For 2D-meshing you must produce a 2D-surface from your solid.
How to produce the 2D-body from the solids?
Steps:
Defeaturing-wb
1+2+3+4: select inner fillets of strut
5: press button, faces are added to list
6: press button, fillets are removed
Arch-wb:
Select all inner faces from the MSH-solid, tube-solids
Press facebinder-tool
Steps:
Defeaturing-wb
Arch-wb:
Hi thomas,
which FC Version did you use for your simulaton?
LP-built
OS: Windows 10 Version 1909
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
It’s a really nice way for solid to shell FEA model conversion in general. However, one has to keep in mind that offset is needed for it to be actual midsurface shell modeling. Is it possible to do it in FreeCAD ? Facebinder’s offset option seems to work differently.thschrader wrote: ↑Wed Aug 11, 2021 10:16 am How to produce the 2D-body from the solids?
Steps:
Arch-wb:
Btw. Facebinder in Draft workbench is the same tool, right ?
