A Mystran writer error when using 1d element
johnwang
Re: A Mystran writer error when using 1d element
Post by johnwang »
if use m, the shape is right. The others all SI.This 25mm rod. Need to use CBAR.
But displacement is 8.35 um. You sure it is in mm?
Mesh_m.dat.txt
(27.9 KiB) Downloaded 46 times
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
bernd
Post by bernd »
does it means your section code only works with meter units?
bernd
Post by bernd »
in FreeCAD everything is in mm. AFAIK length units passed to pyNastran and thus to mystran solver from FreeCAD are in mm as well.
johnwang
Post by johnwang »
For Mystran all should be SI in case file or the American one.
I haven't tested Rect/Pipe, will try tomorrow.
I changed here at exportNastranMesh.py
    # nodes
    kr=0.001
    pynas_nodes = "# grid cards, geometric mesh points\n"
    for node in femnodes_mesh:
        vec = femnodes_mesh[node]
        pynas_nodes += "model.add_grid({}, [{}, {}, {}])\n".format(node, vec.x*kr, vec.y*kr, vec.z*kr)
    # print(pynas_nodes)
johnwang
Post by johnwang »
bernd wrote: Sat Sep 18, 2021 12:11 pm does it means your section code only works with meter units?
In the case file, if the mesh is in mm, the PBAR is calculated with m. They mixed up. So result will not be right.
bernd
Post by bernd »
no Mystran does not need SI units. Mystran will get you back what you have passed to him. I have asked this one to Mystran dev right at the beginning of coding and got repley from a dev. We in FreeCAD pass the same units as we pass to calculix solver. We pass mm and N, with this we get back stress in N/mm2 And thus we pass youngs mofulus in N/mm2. Thus your section code should pass all length units in mm and we will be fine.
See comments at the beginning of calculix writer in source code.
bernd
Post by bernd »
bernd
Post by bernd »
bernd
Post by bernd »
https://github.com/berndhahnebach/FreeC ... ry.py#L116
these lines need to read the data in mm. Than you are fine ...
with this fix in your code, I get 8.35 mm maximum deflection ... :D
https://github.com/berndhahnebach/FreeC ... b8f6a6b28c
