bernd
Posts: 12851 Joined: Sun Sep 08, 2013 8:07 pm
Post
by bernd » Fri Sep 17, 2021 3:45 pm
fyi:
>>> import math
>>> math.pi
3.141592653589793
bernd
Post
by bernd » Fri Sep 17, 2021 4:08 pm
bernd
Post
by bernd » Fri Sep 17, 2021 4:29 pm
FreeCAD FEM 3D truss from solver calculix and z88, see examples gui ... 8145 Meter is surely wrong ...
John have you tested your circular as well?
bernd
Post
by bernd » Fri Sep 17, 2021 4:34 pm
if a rectangular section 222x22 mm is used I get reasonable results ... of 8.1 mm maximal deflection
johnwang
Posts: 1382 Joined: Sun Jan 27, 2019 12:41 am
Post
by johnwang » Sat Sep 18, 2021 3:45 am
PBARL maybe working without the continuation mark.
johnwang on Sun Sep 19, 2021 4:32 am, edited 1 time in total.
johnwang
Post
by johnwang » Sat Sep 18, 2021 8:16 am
bernd wrote: ↑ Fri Sep 17, 2021 4:29 pm
I got the same result.
The Young's Modulus is 200GPa, but the output is small.
change to 200.+09 will gives the right result.
johnwang
Post
by johnwang » Sat Sep 18, 2021 10:53 am
Added more elements. The middle part seems not moving.
bernd
Post
by bernd » Sat Sep 18, 2021 11:27 am
attached with rectangle section. everything seams correct. It can be seen we did not define hinges ... one of the things to do after the sections work correct ...
bernd
Post
we should get this with the circular as well, but something goes wrong with them ...
johnwang
Post
by johnwang » Sat Sep 18, 2021 11:45 am
bernd wrote: ↑ Sat Sep 18, 2021 11:27 am
You need use m for mesh, not mm.
