NASTRAN file format question
chennes
Re: NASTRAN file format question
Post by chennes »
aerospaceweeb wrote: Sat Oct 02, 2021 9:13 pm Another MASSIVE problem is that FreeCAD can't import something, and then export it without changing it in an unpredictable way.
Namely, FreeCAD changes the IDs of every single object in the mesh when it imports it, and then changes the IDs again, in a way I don't fully understand, while exporting it.
The Mesh WB doesn't view the import/export process as an attempt to "edit" a given mesh file -- on import it is throwing away a tremendous amount of data when reading a NASTRAN file, and then it's converting any QUAD4 elements into triangles. Further, when you edit a mesh in FreeCAD's Mesh WB, no particular attempt is made to preserve the original node numbering, because to MeshWB that's not an important part of the mesh. So an exported NASTRAN mesh from MeshWB is unlikely to bear much resemblance to the original imported mesh, even if no changes are made to it. And if you've edited the mesh, it's going to be completely different.
These problems are not insurmountable, but they aren't trivial, either. FreeCAD is designed to be sort of "file-format-agnostic" -- it's not clear that the Mesh WB is the place to code in special handling for something like a NASTRAN file -- to me that feels more like something that should happen in Fem.
Chris Hennes
Pioneer Library System
aerospaceweeb
Post by aerospaceweeb »
I wholeheartedly agree with you Chennes.
I think that's completely reasonable, and I hope to assist in dealing with this problem in the FEM workbench as best I can.
johnwang
Post by johnwang »
chennes wrote: Sun Oct 03, 2021 4:00 pm it's converting any QUAD4 elements into triangles. .
Yes.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
sgrogan
Post by sgrogan »
chennes wrote: Fri Sep 24, 2021 7:24 pm No noise at all, it's an important concern -- keep doing what you do, there are lots of things to keep tabs on!
I get a self-test failure(s) when running from an INSTALLed Windows project.
    m = Mesh.read(f"{self.test_dir}/NASTRAN_Test_GRID_CTRIA3.bdf")
RuntimeError: File does not exist: C:/SoftwareProjects/FreeCAD-testinstall-12.5.4/Mod\Mesh\App\TestData/NASTRAN_Test_GRID_CTRIA3.bdf
The .bsd file(s) are installed in ...MOD/Mesh/Data
A fix could be to install them in ...MOD/Mesh/App/TestData like in the build dir, but is this the best place?
"fight the good fight"
chennes
Post by chennes »
Sorry, that's my mistake -- it looks like I messed up the INSTALL target in the cMake file.
Chris Hennes
sgrogan
Post by sgrogan »
chennes wrote: Mon Oct 11, 2021 9:19 pm Sorry, that's my mistake -- it looks like I messed up the INSTALL target in the cMake file.
No worries, but where best to install test files?
I don't know if we have a convention?
chennes
Post by chennes »
As I recall I modeled this path originally on the OpenSCAD WB, since that's the one I was most familiar with. I don't actually feel strongly about it, if you have a suggestion.
Chris Hennes
sgrogan
Post by sgrogan »
I don't have any strong feelings. Like you, just looking for consistency.
so Mod/Mesh/MeshTest/app ?
Post by Kunda1 »
Using the latest FreeCAD snap edge (nightly) and latest AppImage
When i run the FreeCAD self test, I get the following issues:
RuntimeError: File does not exist: /snap/freecad-ppd/90/usr/Mod/Mesh/App/TestData/NASTRAN_Test_GRID_CTRIA3.bdf
RuntimeError: File does not exist: /snap/freecad-ppd/90/usr/Mod/Mesh/App/TestData/NASTRAN_Test_Delimited_GRID_CQUAD4.bdf
RuntimeError: File does not exist: /snap/freecad-ppd/90/usr/Mod/Mesh/App/TestData/NASTRAN_Test_GRID_CQUAD4.bdf
RuntimeError: File does not exist: /snap/freecad-ppd/90/usr/Mod/Mesh/App/TestData/NASTRAN_Test_GRIDSTAR_CQUAD4.bdf
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.20.26658 (Git)
Hash: 86ee738dff708f8cb54ac1a4ea39092092350ddf
Python version: 3.8.10
Qt version: 5.15.3
OCC version: 7.5.2
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.26651 (Git) AppImage
Branch: (HEAD detached at d357d52)
Hash: d357d524d97db884b9bb562415e6b6d782ec02b4
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
chennes
Post by chennes »
Sorry, this completely fell off my radar (obviously). I still don't know where those files are supposed to go, though.
Chris Hennes
