Translation in FEM
Evgeniy
Re: Translation in FEM
Post by Evgeniy »
chennes wrote: Thu Sep 30, 2021 6:39 pm Maybe, I don't know how it happened in the first place. My understanding is that it's incorrect for their to be any actual translations in the Module.ts files, that all actual translations should be in Module_lang.ts files.
Now I understand what was the mistake. ts file contains:
        <source>Windows</source>
        <translation>Windows</translation>
instead:
        <translation type="unfinished"></translation>
This is very strange.
chennes
Post by chennes »
I'm going to add it to the PR and have Yorik look at it. There really should not be translations in those top-level TS files (and of course if the language isn't specified they won't get used anyway).
Chris Hennes
Pioneer Library System
david69
Post by david69 »
chennes, sorry if I didn't get clearly the meaning of this thread, but can it explain why we still don't see the right translations on the GUI.
when I check crowdin, for example the translation of Solver Calculix has been done 4 yrs ago and we still don't see it.
OS: Ubuntu 18.04.6 LTS (LXDE/Lubuntu)
Version: 0.20.
Branch: unknown
Hash: 09e2e7acfa291ae262f59bc15f79a452dba21851
Python version: 3.6.9
Qt version: 5.9.5
OCC version: 7.5.2
Locale: French/France (fr_FR)
chennes
Post by chennes »
It doesn't seem to be directly related, though maybe Yorik knows better. For example, if I look at the string "Solver CalculiX Standard" (the menu text), I see that it is in the FEM.ts file, and I can see the French translation correctly appearing in the FEM_fr.ts file. The line number doesn't match, though, so maybe it is in fact still out of date? Yorik when did you last sync the CrowdIn with the main repository?
yorik wrote: ping
Chris Hennes
Founder
Post by wmayer »
The ts. files seem very outdated because they reference to files that do not even exist any more. However, this is not the reason why the strings are not translated. The problem is that many context strings do not match any more with the command names.
By rerunning the lupdate tool the issue won't be fixed because for some reason the QT_TR_NOOB/QT_TRANSLATE_NOOB function has been removed in all command classes and thus the Qt utility won't be able to collect any of these strings and add them to the .ts files.
bernd
Post by bernd »
wmayer wrote: Sat Oct 30, 2021 11:03 pm The ts. files seem very outdated because they reference to files that do not even exist any more. However, this is not the reason why the strings are not translated. The problem is that many context strings do not match any more with the command names.
If it is about the Python command classes it probably could have been me. :oops: But in the regard of Python commands it even could have been the case they never ever existet and just noone complained about. :shock:
Would you give an example how it needs to be coded? I would fix them.
Founder
Post by wmayer »
This is rather unlikely because the .ts files include several command-related string literals (e.g. for FEM_ResultShow). When I run pyside2-lupdate
for commands.py the ts file will be empty.
The translation of Python command-related string literals works this way:
  • mark the text with QT_TRANSLATE_NOOP where as first argument you specify the context string. The context string is the one you use to register the command
  • run the script to update the .ts file (done by Yorik)
  • translate the strings and update the .qm files (Yorik and community)
Example code:
Change
class _ResultShow(CommandManager):
    "The FEM_ResultShow command definition"
    def __init__(self):
        super(_ResultShow, self).__init__()
        self.menutext = "Show result"
        self.accel = "R, S"
        self.tooltip = "Shows and visualizes selected result data"
        self.is_active = "with_selresult"
    def Activated(self):
        self.selobj.ViewObject.Document.setEdit(self.selobj.ViewObject, 0)
to
    def __init__(self):
        self.menutext = Qt.QT_TRANSLATE_NOOP("FEM_ResultShow", "Show result")
        self.accel = "R, S"
        self.tooltip = Qt.QT_TRANSLATE_NOOP("FEM_ResultShow", "Shows and visualizes selected result data")
You get
with
from FreeCAD import Qt
bernd
Post by bernd »
wmayer wrote: Mon Nov 01, 2021 12:29 pm
https://github.com/FreeCAD/FreeCAD/comm ... aL901-R621 :oops: :roll:
bernd
Post by bernd »
Evgeniy
Post by Evgeniy »
Of course, a lot of time has passed. Lines for translation appeared. The interface looks much better now.
