Hi, good morning or good afternoon, I have a question about a PCB simulation, in this case, I must simulate in thermal analysis a PCB in step file, this PCB is encapsulated in a aluminum box with inner fixed temperature, but the question is ¿how can I select the parts to add material and set thermical parameters if all of parts are encapsulated, because I can not select the areas and pieces.
Beforehand thank you very much.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Spanish/Mexico (es_MX)
Step file encapsulated PCB FEM Simulation.
- cubito simulation.png (143.37 KiB) Viewed 1474 times
Re: Step file encapsulated PCB FEM Simulation.
Try hiding the parts that obscure the view (click them and use the spacebar) before selecting objects for FEM definitions.
However, this model should be simplified before the analysis - you should remove the unnecessary parts.
yes, you are right, thank you for the answer.
