FEM problem
RobWalker
FEM problem
Post by RobWalker »
Hi Just installed Ubuntu 20.04 LTS and having a problem with FEM in Freecad. The following works on my Windows computer.
1. Open freecad name file and save. Load an .stp file
2 Save again
3 Go to FEM and weight sign appears
4 After a few second Freecad disappears
The same thing happens if I load a sample FEA file.
Any ideas?
Laurie Hartley
Re: FEM problem
Post by Laurie Hartley »
RobWalker wrote: Mon Oct 18, 2021 9:18 pm Hi Just installed Ubuntu 20.04 LTS and having a problem with FEM in Freecad. The following works on my Windows computer.
2 Save again
Any ideas?
Rob - my gut feeling this is more to do with Ubuntu than FreeCAD or the FEM workbench. Nevertheless, it is advisable to post the details of the FreeCAD version you are running.
Click on the help menu, click on “about FreeCAD”. This will copy the info required and you can paste it into a new post.
Plan B - You could also try downloading the latest appimage and running your file on that.
https://www.freecadweb.org/downloads.php
Plan C - give Ubuntu the flick and install MX Linux and install FreeCAD version 19 from the MX installer package manager test repo. ;)
bernd
Re: FEM problem
Post by bernd »
First of all ...
Would you post your FreeCAD version information?
RobWalker
Re: FEM problem
Post by RobWalker »
Thanks for recommendations so far
The version is 0.19 dated 3021/03/11
Rob
david69
Re: FEM problem
Post by david69 »
Rob, it's not enough.
in the red ribbon on top of the forum, you got indications how to get and post your freecad information which I copy here:
Please provide your FreeCAD version info - (scroll further down this page if you wish to see a video on how to do this created by Mario52)
Open the Help --> About FreeCAD menu then click on the "Copy to clipboard" button, and paste its content in the text input area. This will provide us valuable information on your exact version and revision number, your operating system as well as FreeCAD's internal libraries. (Mac users: the About FreeCAD menu is under the FreeCAD menu.)
RobWalker
Re: FEM problem
Post by RobWalker »
Hi
Please see copy of info
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.0
Thanks
Rob
Laurie Hartley
Re: FEM problem
RobWalker wrote: Thu Oct 21, 2021 5:54 pm Hi
Build type: Unknown
Qt version: 5.12.8
OCC version: 7.5.0
Thanks
Rob
Rob - I am no expert but I think your problem may be related to Qt version 12 on Ubuntu Core.
https://forum.snapcraft.io/t/qt-5-12-on ... ions/22260
As there have been no other suggestions why not make a live USB of a different version of Ubuntu (or another OS) - install FreeCAD and try to run the problem STL file. If it opens you have narrowed down your problem.
bernd
Re: FEM problem
Post by bernd »
Are you sure it is a FEM problem?
Does your problem only happens if you switch to FEM and open a FEM analysis file.
If it would happen on other files and other workbenches as well, it would mean it is not related to FEM and you need to look somewhere else to solve the problem.
RobWalker
Re: FEM problem
Post by RobWalker »
Good evening
Thanks for the suggestion to try another OS. I will give that a try but probably not for a few days.
Freecad crashes when trying to load the demonstration files provided with Freecad and the .stp file loads OK into Part Design so it is not the .stp file causing the problem.
Thanks
Rob
user1234
Re: FEM problem
Post by user1234 »
RobWalker wrote: Mon Oct 25, 2021 9:04 pm Freecad crashes when trying to load the demonstration files provided with Freecad and the .stp file loads OK into Part Design so it is not the .stp file
Sorry, but for me it is not explicit. A general example file or the FEM example files.
Greetings
user1234
