My FEM fails. How to get further?
Roland
Post by Roland »
Dear FEM experts,
I feel a novice in FEM.
This is my model:
I want to analyse its strength if an axis (purple) is placed as indicaded and presses downward.
I prepared two approaches, of which none succeeded so far.
  • The one based on shells fails with a CalculiX execution error: "ERROR in gen3dnor: size of estimated shell normal in node 7 element 11790 is smaller than 1.e-10." I have no idea what I can do to avoid this error.
  • The approach based on a solid yields a few meshing errors. To an extend that CalculiX doesn not like it.
Could somebody advise a suitable way forward? Improve the shells approach or the solid approach? Or otherwise?
Thanks for your consideration!
Roland
on:
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Bearing1_Shells_FC19.FCStd
(32.02 KiB) Downloaded 40 times
Bearing1_Solid_FC19.FCStd
(222.28 KiB) Downloaded 44 times
NewJoker
Re: My FEM fails. How to get further?
Post by NewJoker »
Kunda1 wrote:
Could you move it to FEM subforum ?
Roland wrote:
1) shell model:
It fails because of inconsistent shell element normals (you can see them when you look at the created mesh). I don’t know how FreeCAD’s FEM module handles those but in CalculiX itself normal direction is controlled by the order in which nodes are specified under *ELEMENT.
2) solid model:
You should simplify it for the purpose of the analysis - remove small details. In this case you get nonpositive jacobian determinant errors. To eliminate them you can try further refining the mesh. If this doesn’t help, here are some other workarounds:
https://wiki.freecadweb.org/FEM_MeshGmshFromShape
bernd
Post by bernd »
moved to FEM
Roland
Post by Roland »
1/ Thanks NewJoker. Can go ahead with your suggestions
2/ Bernd: I posted in the Users forum because I asked for help on usage. I do not see my novice level questions as assisting to FEM Development. But I am glad that my question was noticed. In the near future, all usage questions regarding FEM to Fem Dev?
Greetings from NL
Roland
NewJoker
Post by NewJoker »
Roland wrote: Tue Jan 04, 2022 11:44 am 2/ Bernd: I posted in the Users forum because I asked for help on usage. I do not see my novice level questions as assisting to FEM Development. But I am glad that my question was noticed. In the near future, all usage questions regarding FEM to Fem Dev?
This subforum is actually a place for all questions regarding FEM, even though it belongs to the Development group.
bernd wrote:
To make it clear for future posters (as it can be quite confusing at the moment), could you add a note (to the current About the development of the FEM module/workbench) that this forum is a place for general discussions about FEM module ?
-alex-
Post by -alex- »
As @NewJoker said you should simplify your model by removing small details.
Then you can use Draft_Facebinder to get a 2D shell model. Then you can apply 2D contact constraint between the frame and the cylinder.
You have to let a bit of play between frame and cylindre to avoid "fusion" of mesh elements.
Because of contact analysis, do not forget to fully constrain the cylindrical part, otherwise the solver will not converge.
Report here if you face difficulties.
Roland
Post by Roland »
Thanks Alex.
1/ I never used Facebinder. I made those models by Part Fuse (accepting the warning against fusing faces). Upon using Facebinder for the first time I observe that Facebinder does not include some of the shells into the created item. Does this tell me something about the quality of whether or how the faces touch each other?
(Apology if this is too basic for FEM)
2/ I did not use the cylinder to apply a force. Perhaps that is possible.
Roland
Post by Roland »
BINGO!
Problem solved.
How? Perhaps:
I shall appreciate your view of cause and solution.
Greetz
Roland
Roland
Post by Roland »
Horrible! I cannot confirm that my diagnosis of the reason for failure is correct.
The solution works anyway!
Roland
