Hi NewJoker, Finally I obtained the same results in PrePoMax, I was doing simulation using ''Coupled temperature-displacement step'' when it should be ''Heat transfer step'', but I have the same question, Why Freecad do bad calculations?, in freecad I changed 6 W/m2 instead 3409 W/m2 and the results are similar. even in the video shared I didn't make an error (I hope).NewJoker wrote: ↑Mon Feb 14, 2022 6:46 pm It's not the fault of CalculiX because I solved your model using another preprocessor for this solver and the results agree with SolidWorks Simulation very well. Be extremely careful when applying heat fluxes (concentrated or surface fluxes) to multiple faces unless you are sure that you know how particular software handles it. In SolidWorks you have the "per item" option so you can be sure that the specified value is applied to each face. Otherwise, it's common in FEA software that the specified value is uniformly distributed on all the selected faces (so that each face is loaded with a fraction of total specified flux). The same applies to nodes within a face - sometimes the specified concentrated heat flux may be applied to each node while sometimes it will be distributed over the face so that each node receives a fraction of the specified flux. I'm not sure how it works in FreeCAD since it's not mentioned in the documentation and there might be some bugs. I will try to take a closer look at this if I have time, some simple tests and examination of the exported input file will be needed to verify how it works here.
beforehand thanks a lot.
