I want to use tetgen for re-meshing part of a cube. This is the first time I am using this software. I have already executed the C++ code given in the manual and it works fine. Now, I wish to re-mesh a part of a cube but I am confused as to how should I start the code or how should I pick certain faces/edges to be re-meshed. Any help would be appreciated.
Thanks
PG
TETGEN
Re: TETGEN
Hi
Did you mean Netgen
http://sourceforge.net/projects/netgen-mesher/
or do you really mean Tetgen?
www.tetgen.org
Jim
Did you mean Netgen
www.tetgen.org
Jim
Re: TETGEN
No, I meant Tetgen. (http://wias-berlin.de/software/tetgen/)
Re: TETGEN
FreeCAD uses the salome smesh library for volume meshing. You find the code in freecad's 3rd party folder https://github.com/FreeCAD/FreeCAD_sf_m ... alomesmesh
You could have a look at the netgen plugin and how it works and then create such a plugin for tetgen. than it could be easily integrated into freecad.
To see how smesh it is integrated into freecad you need to dig through the fem workbench, I never studied the code for it so I don't know it.
As far as I know it smesh is also used from within the mesh workbench for surface meshing. You could also look there how a possible tetgen plugin could be integrated.
Re: TETGEN
Tetgen is under (A)GPL and there fore not usably to FreeCAD...
Stop whining - start coding!
Re: TETGEN
Thank you ickby and jriegel for your pointers and comments.
