Jacobian Error Woes
Bimdan
Re: Jacobian Error Woes
Post by Bimdan »
Wow that scares me off even trying that! lol
Out of interest: I'm not asking for the answer as I will go off and do my own homework but is it possible in FreeCAD to do (probably going to use the wrong terminology here) a reverse calc or set a limit. For example, I want to work out the temperature limit for 0.5mm deformation, currently, I do this manually by upping the temp until I get close to said limit?
NewJoker
Post by NewJoker »
Not only FreeCAD FEM but also pretty much all the other FEA tools don’t provide any built-in tools for that and you have to either do it manually or write a script (usually using Python) that will do this for you automatically.
Bimdan
Post by Bimdan »
Fair enough and thank you
