Porblem with remeshing a body/object through GUI
S-Y.Chen
Post by S-Y.Chen »
Hi everyone,
After I have done a FEM analysis, how do I re-define the mesh size, and re-do the analysis ?
I have cleared the FEM Mesh in GUI, but I jwhen I double-clicked the "FEMMeshGmsh", nothing poped up or happened. Recompute does not do anything either.
Am I missing anything here ?
Regards
S-Y. Chen
NewJoker
Re: How to remesh a body/object ?
Post by NewJoker »
Which version of FreeCAD do you use ? Double-clicking the FEMMeshGmsh should open its settings window where you can remesh.
S-Y.Chen
Re: Porblem with remeshing a body/object through GUI
Post by S-Y.Chen »
I am using 0.20
Yes I did double-click the FEMMeshGmsh. It is not showing the dialog box that I can perform the remesh action.
I have attached the model file here, which is a very simple cantilever beam. I am suspecting there is a bug in FreeCAD, because sometimes it works, and sometimes it doen't. Unfortunate I can't figure out how to reproduce the problem yet.
But the model I have attached does seems to have a problem for remeshing in GUI. It works OK if I just use Python scripts.
Regards
S-Y.Chen
examp104-T02.FCStd
(731.15 KiB) Downloaded 26 times
S-Y.Chen
Post by S-Y.Chen »
I am wondering if anyone can give a try to the model I uploaded. I am not sure if I have done anything wrong.
I suspect this is a bug in FreecAD
