OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.19.
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
Good day everyone, above is my OS version
I've only used the FEM workbench twice and it treated me well the first time though the second time I had an issue with creating a mesh. When I constrain the parts of the analysis,
I created an Analysis that holds:
=the Calculix solver,
=selected material card Steel-Generic
=The fixed 2 bottom faces,
=applied compression force of 16060 newtons.
When it was time for me to create the Gmsh there was the following yellow message in my report view[Fem::FemMeshObjectPython / FEMMeshGmsh: Links go out of the allowed scope]. I closed the application then went to my terminal and updated my system in hopes it would work and when I came back the yellow message was not there though when I applied the mesh there would be red messages in the report view followed by a timer that won't stop running. I followed the exact same order and logic as I did the precious time though the mesh ends up not rendering. I've attached images of my failed attempt and successful attempt at creating a mesh.
Any help would be greatly appreciated
Gmsh not rendering(keeps running non-stop)
- here is the part where i managed to successfully render the mesh
- successful Gmsh render.png (180.7 KiB) Viewed 702 times
- The image of when the Gmsh would not work
- Part 15 Gmsh issue.png (172.75 KiB) Viewed 702 times
Re: Gmsh not rendering(keeps running non-stop)
Hello, sorry for late reply.
Can you post your FreeCAD-file?
Reduce file-size:
In model-tree, right click on gmsh-object, "clear mesh".
Thanks.
Reduce file-size:
Thanks.
