[fixed]: Thermomech analysis: split inp writing = true stops ccx
thschrader
Post by thschrader »
Test-file:
bimetalFEM.FCStd
(13.49 KiB) Downloaded 22 times
In solver data-Tab set "Split Input Writer=false" ==> ccx runs
With "true" option ccx stopps with this message:
CalculiX Version 2.17, Copyright(C) 1998-2020 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Thu Jul 23 21:43:50 CEST 2020
*ERROR in readinput: cannot open file FEMMeshGmsh_constraintstemperaturenodesets.inp
0.3: CalculiX execute error:
0.3: Loading result sets...
Done with:
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * BIM
  * CfdOF 1.17.6
  * Curves 0.3.0
  * Defeaturing_WB
  * dodo
  * Fasteners
  * FEM_FrontISTR 0.1.0
  * Manipulator 1.4.3
  * Plot
  * Reinforcement
  * WorkFeature
NewJoker
Re: Thermomech analysis: split inp writing = true stopps ccx
Post by NewJoker »
I can confirm this in 0.20 and 0.21, although I get a different error message:
FEM: No frd result file found at ...
Version details:
Version: 0.20.29177 (Git)
Locale: Polish/Poland (pl_PL)
Version: 0.21.30058 (Git)
Hash: cb96332a64db8ae855ca700212eebb0f5151230a
fandaL
Post by fandaL »
The input is split to few files and Calculix searches for:
"FEMMeshGmsh_constraintstemperaturenodesets.inp"
but this file written by FC contains spaces in the name:
"FEMMeshGmsh_constraints temperature node sets.inp"
When I deleted spaces manually, ccx runs well.
Tested on
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.20.29177 (Git) Snap 161
Branch: tag: 0.20
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Post by Kunda1 »
That looks like a simple fix. But I can't find "FEMMeshGmsh_constraints" in the FC source code. Any idea why?
johnwang
Post by johnwang »
Kunda1 wrote: Sat Aug 13, 2022 1:14 am That looks like a simple fix. But I can't find "FEMMeshGmsh_constraints" in the FC source code. Any idea why?
It's in Mod/Fem/femsolver/calculix/write_constraint_temperature.py
Ref: https://github.com/FreeCAD/FreeCAD/blob ... ure.py#L33
Change line 33 & 34 from :
def get_sets_name():
    return "constraints temperature node sets"
to:
    return "constraints_temperature_node_sets"
It will generates FEMMeshGmsh_constraints_temperature_node_sets.inp
the same way as write_constraint_fixed.py and other modules do.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
Post by Kunda1 »
Thanks! PR in issue #7361
uwestoehr
Post by uwestoehr »
Kunda1 wrote: Sat Aug 13, 2022 1:57 pm Thanks! PR in issue #7361
The fix was merged and backported. To benefit from it, take the latest patch collection: https://forum.freecadweb.org/viewtopic.php?f=18&t=71058
thschrader
Re: Thermomech analysis: split inp writing = true stops ccx
Used your patch, works now. Thanks.
