Elmer/FreeCAD disappears when running simulation
Founder
Re: Elmer/FreeCAD disappears when running simulation
Post by wmayer »
thschrader wrote: Sun Aug 14, 2022 10:01 am When the sim seems to come to an end, suddenly FC disappears completely.
There are two things you should do:
  • Start FreeCAD with the option --write-log. You will find FreeCAD.log in %APPDATA%\FreeCAD
  • Check if you can find a file crash.dmp with a suitable time stamp in %APPDATA%\FreeCAD or a sub-directory there
thschrader
Post by thschrader »
wmayer wrote: Mon Aug 15, 2022 5:01 pm There are two things you should do:
Here are the log/dmp files with test example for elmer:
beamElmer.FCStd
(10.99 KiB) Downloaded 13 times
FC_log_dmp_files.zip
(66.36 KiB) Downloaded 14 times
Founder
Post by wmayer »
These are the last function calls:
Log: Id: 13468: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BF46656)
Log: Id: 13468: 00007FFC6BF46656 (nglib): (filename not available): netgen::HPRefinement
Log: Id: 11340: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BF47299)
Log: Id: 3436: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BF47299)
Log: Id: 11340: 00007FFC6BF47299 (nglib): (filename not available): netgen::HPRefinement
Log: Id: 3436: 00007FFC6BF47299 (nglib): (filename not available): netgen::HPRefinement
Log: Id: 13468: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BF472CF)
Log: Id: 13468: 00007FFC6BF472CF (nglib): (filename not available): netgen::HPRefinement
Log: Id: 11340: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BE573C0)
Log: Id: 11340: 00007FFC6BE573C0 (ngcore): (filename not available): ngcore::TaskManager::Loop
Log: Id: 3436: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BE573C0)
Log: Id: 3436: 00007FFC6BE573C0 (ngcore): (filename not available): ngcore::TaskManager::Loop
Log: Id: 13468: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BE573C0)
Log: Id: 13468: 00007FFC6BE573C0 (ngcore): (filename not available): ngcore::TaskManager::Loop
Log: Id: 11340: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BE55074)
Log: Id: 11340: 00007FFC6BE55074 (ngcore): (filename not available): ngcore::TablePrefixSum64
Log: Id: 3436: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BE55074)
Log: Id: 13468: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFC6BE55074)
Log: Id: 3436: 00007FFC6BE55074 (ngcore): (filename not available): ngcore::TablePrefixSum64
Log: Id: 13468: 00007FFC6BE55074 (ngcore): (filename not available): ngcore::TablePrefixSum64
So, it's obviously a crash caused by netgen when doing a refinement.
Inside FreeCAD.log there is this message:
(Parent is QTextDocument(0x1b1965f6230), parent's thread is QThread(0x1b196606550), current thread is QThread(0x1b1d8bc1220)
Err: Illegal storage access...
Log: Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt.
You must not let any exception whatsoever propagate through Qt code.
If that is not possible, in Qt 5 you must at least reimplement
QCoreApplication::notify() and catch all exceptions there.
Err: Event loop left through unknown unhandled exception
I am not sure why Qt prints this output since we have already re-implemented QCoreApplication::notify() and handle all exceptions there. But maybe the problem is caused when a segmentation fault occurs inside a thread.
