Ticket #4207 - loft crashes on my machine
idobox
Postby idobox » Wed Nov 27, 2019 8:56 pm
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
CPU/GPU : AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx CPU (integrated GPU).
When trying to use loft in the part design WB, either additive or substractive, the view does not update to show the loft operation happened.
If I then try to change anything to the view, like the viewing angle or scale, the software freezes indefinetely, and the only way out is to get windows to force close it.
This only happens on my new laptop, which uses a new generation AMD Ryzen CPU with integrated GPU. Not on my 'main' computer, with an I5 and a GTX 1060.
How to reproduce the bug.
1. Create a new file
2. Go to part design workbench
3. Draw a simple sketch on XY plane, ie a rectangle
4. Draw another simple sketch either on a different plane, or on a parrallel plane
5. select one sketch
6. click additive loft
7. Click add section
8. click on the second sketch
9. try to do anything except ctrl+S
I have found that saving the file quickly after validating the loft operation works. I can then close the file, open it again, and the part will be updated, showing the loft operation went well. It's a usable workaround, but a really annoying one.
I have also tried to change the sketches once the whole loft/save/close/reopen routine is done, and the software reacts normally.
To me, it looks like an issue when the software tries to display the curved suface for the first time. Since it only happens on my laptop, which uses a pretty recent generation of integrated GPU, I imagine it could be caused by hardware taht is supported less than ideally.
But what do I know? :)
Anyway, I'm joining two files.
One with two sketches before running the loft operation.
The other one, saved just after the loft operation.
loft test pre.FCStd
(6.65 KiB) Downloaded 17 times
loft test post.FCStd
(11.78 KiB) Downloaded 16 times
Reason: Added ticket number to thread title
Re: bug: loft crashes on my machine
Postby chrisb » Wed Nov 27, 2019 10:39 pm
Hi and welcome to the forum!
Please retry with a current 0.19 version.
cycore
Postby cycore » Fri Dec 06, 2019 2:02 pm
I can confirm this crash in 0.18.4. Its not only the loft operation, but also the additive and subtractive primitives that crash in the same way.
It works in the most recent 0.19 version (FreeCAD_0.19.18831_x64_Conda_Py3QT5-WinVS2015).
Re: Ticket #4207 - loft crashes on my machine
Postby Kunda1 » Sat Jan 11, 2020 12:54 pm
idobox wrote::bell:
Looks like it's fixed in 0.19. Can you reproduce on the latest 0.19pre and report back?
Ref: issue #4207
