Feature: offset tool in sketcher
bleber
Re: Feature: offset tool in sketcher
Postby bleber » Thu Sep 24, 2020 10:07 pm
I test the scipt and works fine, good work!
Some easi feature: Mantain offset mode with ruberband to make multiple offsets until clik right mouse key to leave offset mode.
RandomUser
Postby RandomUser » Sun Oct 11, 2020 3:53 am
I'm running into a few issues while trying to use the 3.0 version of the macro.
  File "/home/test/Downloads/OffsetInSketcher03.FCMacro", line 418, in <module>
    ex = OffsetDialog()
  File "/home/test/Downloads/OffsetInSketcher03.FCMacro", line 19, in __init__
    self.SelGeoId = self.getElements() # init the command
  File "/home/test/Downloads/OffsetInSketcher03.FCMacro", line 66, in getElements
    point = Sketch.getSketchPoint(SelGeoId[0]) # start of rubber band
<type 'exceptions.TypeError'>: unbound method getSketchPoint() must be called with Sketch instance as first argument (got int instance instead)
and
  File "/home/test/Downloads/OffsetInSketcher03.FCMacro", line 45, in getPoint
    OffsetInSketcher.addOffset(self.SelGeoId,self.OffsetLine) # call the command
AttributeError: OffsetDialog instance has no attribute 'SelGeoId'
OS: Debian GNU/Linux 10 (buster)
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
edi
Postby edi » Tue Oct 13, 2020 3:22 pm
@RandomUser:
Use the workflow:
- open a sketch
- draw some lines and/or arcs (like in the examples above)
- select at least one element
- start the script
paullee
Postby paullee » Sun Oct 18, 2020 12:30 am
Not reading every line in the whole thread but sounds useful :D
FWIW -
  1. For reference Draft Gui has a tool for Offset, which internally use a few Draft functions by memory offset() offsetWire()
  2. Arch Wall also use offsetWire(), to 'thicken' a wire on 2d plane and extrude 'upward' to build a 3d wall.
See the effect of both tool in screencaptures and files below.
p.s.
It seems there is some bugs in Draft Offset ? - The distance between the 2 offsetted (blue) arcs to the original (white) arc seems different :?:
Anywall, it doesn't affect ArchWall.
OffsetTest_ r.FCStd
(25.09 KiB) Downloaded 4 times
Screenshot from 2020-10-18 08-22-18.png (208.34 KiB) Viewed 182 times
Screenshot from 2020-10-18 08-25-15.png (219.6 KiB) Viewed 182 times
Screenshot from 2020-10-18 08-25-57.png (326.71 KiB) Viewed 182 times
Postby Kunda1 » Sun Oct 18, 2020 11:49 am
p.s.
Is this related to issue #3859?
If not please open a ticket, thanks!
paullee
Postby paullee » Sun Oct 18, 2020 5:20 pm
Not the same issue, at least not directly related (maybe the underlying Draft / OffsetWire() / Offfset() problems)
But it seems the behaviour is not consistent ... can someone confirm... maybe to discuss in separate thread.
p.s.
The purpose of bringing up Draft Offset is just want to highlight this tool has not problem with 2 arc not tangentially connected, just if they are still connected after offsetting.
OffsetTest_ r2.FCStd
(27.05 KiB) Downloaded 3 times
Screenshot from 2020-10-19 01-16-15.png (259.36 KiB) Viewed 113 times
Screenshot from 2020-10-19 01-16-17.png (273.31 KiB) Viewed 113 times
edi
Postby edi » Mon Oct 19, 2020 12:25 pm
I know, the tread has become long, but I want to note the following:
If arcs are not tangentially connected to their neighbours, its's easy to find indefinable situations, see screenshot:
In the two pictures, the left lines are the original: Two lines and an arc with radius 5.
- The left figure using offset value 2 is easy to calculate. Two lines and an arc lead to two lines and an arc.
- The right figure having offset value 4 will lead to only one single line. (or two lines which are in line)
You will find situations, where no reasonable solution is available.
