[Bug] placement of boolean base propagates to secondary body
CluelessJunk
Re: [Bug] placement of boolean base propagates to secondary body
Postby CluelessJunk » Sat Jan 28, 2017 2:46 pm
I recompiled with debug information and did a new backtrace:
edit It seems, the old backtrace already contained all the information... whatever, then at least take the current build data
OS: "Fedora release 25 (Twenty Five)"
Version: 0.17.9592 (Git)
Build type: Debug
Hash: c2f2a250549163947592069262ce1cd3328b3669
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
ickby
Postby ickby » Sun Jan 29, 2017 3:54 pm
I think the behavior is as expected and works correct the way you described it. In PartDesign you need to think a bit different. The boolean operation is a feature of the body, not a standalone operation/object as in Part. The Body001 is the container for all its features, including the boolean. Changing its placement must not change the shape, only the location of the shape. However changing Body, which is used in the boolean, can change the shape as it is used in a feature of Body001. Everything is ok.
CluelessJunk
Postby CluelessJunk » Mon Jan 30, 2017 6:45 am
@ickby I'm sure its not expected behaviour. At one moment, the rotation is not applied to the second boolean part and as soon as you update the rotation value, the other part jumps to the place with the value applied.
The value should either be applied or not applied, but now it depends on whether you updated the value or not.
ickby
Postby ickby » Mon Jan 30, 2017 7:04 am
Could you alaborate a bit more in detail what you mean with applied and jump? I tested the sequence you have given in the Bug report, and the placements are correctly applied to either the top body, moving the whole shape, or the one used in the boolean, chanign the shape. Do you mean that the shape is not updated "real time" while chaning the boolean body placement, but only on "enter"?
Buy the way, one bug I noticved is thatthe boolean operation does not hide the body it uses automatically, thats annoying.
CluelessJunk
Postby CluelessJunk » Mon Jan 30, 2017 2:22 pm
For a moment I thought you were right, but as of r9586 (a bit old I know) its still not working. I made some screenshots:
Does it work differently for you?
ickby
Postby ickby » Mon Jan 30, 2017 7:06 pm
It works excactly the same for me, and this is intended and correct bahaviour. Why should it be different?
CluelessJunk
Postby CluelessJunk » Tue Jan 31, 2017 5:53 am
How can this be intended? At one moment, the Angle values are 60° on the outer and 0° on the inner boolean object, resulting in a a difference between the cube of 30° and a rotation of both of 30°. The next moment the values are 60° and 1° resulting in a angle of the cubes of 59° and a rotation of 1°. Going back to 0°, the resulting values are 60°/0° instead of 30/30 as before. This can't be intended.
edit I called the second screenshot "correct", but that is only in a certain view the case. I changed the angle by 30°, so the entire thing should rotate by 30°. But now the angle between the cubes is still 30°, but that value is stored nowhere, there is only 60° and 0°. Thats the reason that as soon as one updates the second value, since that initial 30° is stored nowhere, it snaps to an angle difference of 60°. So rotating the base does not properly rotate the children (unless you never update their values).
ickby
Postby ickby » Tue Jan 31, 2017 7:46 am
Ah ok now I can reproduce. I always set the Body001 placement back to default (30° in your example) and than it worked. But if one leaves it at 60° I see the jumps. Yes definitely a bug. Thanks for explaining in detail.
nemesis
Postby nemesis » Sun Feb 12, 2017 2:25 pm
sut ti be sure I'm on the same bug, changing placement of the body used for the boolean operation (the tool one) it doesn't impact the result.
OS: Mac OS X
Version: 0.17.10064 (Git)
Branch: (detached from d7ed8c4)
Hash: d7ed8c4383f394f64dd9314eefa00efae02fb32f
Coin version: 3.1.3
OCC version: 7.0.0
TestMultifeature.FCStd
(64.97 KiB) Downloaded 32 times
Postby Kunda1 » Wed May 31, 2017 11:51 am
ickby wrote:Buy the way, one bug I noticved is thatthe boolean operation does not hide the body it uses automatically, thats annoying.
Should I open a ticket for this?
cron
