PartDesignNext Diagram
wandererfan
Postby wandererfan » Tue Jul 19, 2016 3:28 pm
I made this diagram to help me understand PDN. Would appreciate it if experts could confirm or refute my understanding.
Next step is to figure out how all the various Placements work together.
Thanks,
wf
PDN.pdf.zip
not really a zip file
(23.85 KiB) Downloaded 156 times
DeepSOIC
Re: PartDesignNext Diagram
Postby DeepSOIC » Tue Jul 19, 2016 3:41 pm
<offtopic> I dislike when files are uploaded with fake extensions to avoid extension blocks. Just because getting this PDF requires more steps from my side compared to if it were an actual zip containing a pdf. I have to save it, then locate the saved file, change extension, and then open. Compared to opening the link + opening the file from within zip unpacker program. </offtopic>
DeepSOIC
Postby DeepSOIC » Tue Jul 19, 2016 3:59 pm
Things that do not look all right to me:
Part contains bodies - no. Not only bodies, and not even only Part::Features.
And it is unclear to me, what you meant by "Body contains Doc Object". Body isn't supposed to contain arbitrary doc objects.
It's a hard question if Body can contain Draft objects. It may be possible technically, but there is no GUI tools for that apart from using one as base feature for body.
I'd differentiate them as so:
* Part is a general-purpose container with Placement.
* BodyBase is a container with placement, that has Shape. Shape of body is supposed to provide the final geometry (usually, solid) that was the goal of all the objects the body contains.
* Body is a derivative of BodyBase, specialized for PartDesign. Its shape is guaranteed to be a single solid (or empty, if body is incomplete).
DeepSOIC
Postby DeepSOIC » Tue Jul 19, 2016 4:02 pm
Another thing is that it is planned to change implementation of all this part-body stuff. See this thread:
viewtopic.php?f=10&t=15490
So I advise you to not go terribly in-depth on supporting them.
ickby
Postby ickby » Tue Jul 19, 2016 4:35 pm
as deepsoic noted the implemention of Containers is ongoing. I'm currently finalising my "Extension" implementation, but well, it's summer, life is fast and coding progress is slow :)
I'm not perfectly familiar wit the code shema you have in your pdf, but I try:
1. Part and body always contain exactly one Origin. Local coordinate systems in freecad can exist without origin, but those two objects are OriginGroups which always have one.
2. Body cannot hold arbitrary document objects. But Part can, hence this little box should be moved to Part
3. Body can only hold PartDesing::Feature, no Part Feature and no Draft objects. There may be other objects with a shape like body that can group more general in the future, but currently not.
wandererfan
Postby wandererfan » Wed Jul 20, 2016 11:56 am
Thank you. I understand a little better.
wf
sgrogan
Postby sgrogan » Thu Jul 21, 2016 1:29 am
This is a very informative thread.
@wandererfan, any chance for an updated version of your diagram? I think it helps ickby and DeepSOIC answer the questions.
It definitely brings me closer to understanding how PDN is designed to work.
bejant
Postby bejant » Thu Jul 21, 2016 10:08 am
Diagram from the OP:
My Part Design tutorials on YouTube (aimed at beginners).
wandererfan
Postby wandererfan » Thu Jul 21, 2016 2:33 pm
sgrogan wrote:@wandererfan, any chance for an updated version of your diagram?
The original is in Dia (Gnome's Visio) if anybody wants a copy, I'll post it.
wf
PDNDiagramv2.zip
Really a zipped pdf!
(22.76 KiB) Downloaded 18 times
NormandC
Postby NormandC » Thu Jul 21, 2016 2:45 pm
wandererfan wrote:Really a zipped pdf!
yorik, Jim, what do you guys think of adding PDF to the list of supported filetypes by the forum? I don't remember why we didn't in the past.
