[FIXED] FC#3006: PartDesign Mirrored bugs
abdullah
Re: FC#3006: PartDesign Mirrored bugs
Post by abdullah »
It is the transformation/inter-matrix-format-conversion itself what makes the colors go:
test code:
            double trsl=0;
            std::list<gp_Trsf>::const_iterator trsf = (o->second).begin();
            for (unsigned int i=0; i < (o->second).size(); i++,trsf++) {
                trsl+=40;
                /*Base::Matrix4D mat;
                Part::TopoShape::convertToMatrix(*trsf,mat);*/
                Base::Matrix4D mat;
                mat.setToUnity();
                mat.move(0,trsl,0);
                mats[i] = convert(mat);
abdullah
Post by abdullah »
I have tried among others removing different types of transparency, removing the transparency.
I think it is a problem of the transformation and the light. I do not have enough rendering knowledge to be sure, but I think this happens because the transformation is a mirrored transformation, so it is not just a rotation and scaling, but a multiplication by a negative value.
In my test:
            double trsl=0;
                trsl+=9;
                Base::Matrix4D mat;
                mat.setToUnity();
                mat.scale(-1.0,-1.0,-1.0);
                mat.move(0,trsl,0);
                //Part::TopoShape::convertToMatrix(*trsf,mat);
without the "scale" line, the cubes are red, with it they are black.
I think it might be related to the direction of the normal of the faces of the mesh after transformation. However, as I said, it is pure speculation as I deeply ignore this topic. Maybe somebody more knowledgeable can throw some light (at least to the cube so that it shines red :lol: ).
ickby
Post by ickby »
If the normals of the cubes triangles point to the inside their back would be exposed, which is normally not exposed to light, hence black. To test the you can go to the preferences and enable backlight with a certain Colour. If black changes.to that colour your are.sure.that those are.triangle backsides and that somewhere a invertion has happened.
abdullah
Post by abdullah »
ickby wrote: Fri Jun 09, 2017 3:30 am If the normals of the cubes triangles point to the inside their back would be exposed, which is normally not exposed to light, hence black. To test the you can go to the preferences and enable backlight with a certain Colour. If black changes.to that colour your are.sure.that those are.triangle backsides and that somewhere a invertion has happened.
It seems like some faces have changed color...
abdullah
Post by abdullah »
Well, quite confirmed it is the normals, I just inverted the normals and I get:
so red goes black, and black goes red.
The problem: if SoMultipleCopy does not have an option to change the direction of the normals of one or more copies, then we might end up adding multiple copies, so repeating the objects, at least if we want it to be red instead of black/red. I do not know if this can be considered to be a Coin3d bug.
kkremitzki
Post by kkremitzki »
abdullah wrote: Fri Jun 09, 2017 4:41 am Well, quite confirmed it is the normals, I just inverted the normals and I get:
Yep, I was poking around with the rejectedMaterial definition trying out some other options as well:
I know it's probably the wrong solution, but it should be possible to define a material that looks the same from "inside" and "outside" right?
abdullah
Post by abdullah »
kkremitzki wrote: Fri Jun 09, 2017 5:34 am I know it's probably the wrong solution, but it should be possible to define a material that looks the same from "inside" and "outside" right?
I was thinking making two either colocated or slightly separated faces with normals in the opposite direction, so that when it is inverted the innerface has the right normal. Something like a reversible jacket...
abdullah
Post by abdullah »
In fact after some testing, and googling, I have come to the same conclusion:
https://grey.colorado.edu/coin3d/classS ... ceSet.html
A fairly common request when rendering facesets is how to display a set of faces with different colors on the backside versus the frontside. There is not direct support for this in the API, but it can easily be implemented by duplicating all faces in both the SoShapeHints::COUNTERCLOCKWISE and the SoShapeHints::CLOCKWISE order. Here is a simple usage example, showing the technique for a single polygon, using two SoFaceSet nodes for rendering the same polygon from both sides:
#Inventor V2.1 ascii
Separator {
Coordinate3 { point [ 0 0 0, 1 0 0, 1 1 0 ] }
Separator {
Material { diffuseColor [ 1 1 0 ] }
ShapeHints {
vertexOrdering COUNTERCLOCKWISE
shapeType SOLID
FaceSet { numVertices [ 3 ] }
Separator {
Material { diffuseColor [ 1 0 0 ] }
ShapeHints {
vertexOrdering CLOCKWISE
shapeType SOLID
The same effect can also be done in the following manner, using an SoIndexedFaceSet to explicitly render the polygon coordinates in both directions (clockwise and counterclockwise):
Separator {
Material { diffuseColor [ 1 0 0, 1 1 0 ] }
MaterialBinding { value PER_FACE_INDEXED }
ShapeHints {
shapeType SOLID
IndexedFaceSet {
coordIndex [ 0, 1, 2, -1, 2, 1, 0, -1 ]
materialIndex [ 0, 1 ]
abdullah
Post by abdullah »
Not necessarily. What did you change so that you can see the cubes with light/dark red?
EDIT: I guess you set an emissiveColor.
kkremitzki
abdullah wrote: Sat Jun 10, 2017 5:30 am
That's right, I was messing around with the different types of color that could be set, and I think in that screenshot it was emissiveColor.
