Boolean-Fragments as Boolean operation in PDN
Re: Boolean-Fragments as Boolean operation in PDN
Postby chrisb » Fri Jun 01, 2018 7:38 pm
I don't see at the moment the benefit of switching workbenches. Why don't you model the complete nut in one body?
user1234
Postby user1234 » Fri Jun 01, 2018 8:51 pm
This is the problem, CompSolids are not available in the PartDesign Workbench. So i have to swich to the Part Worckbench (and mix it). And the Parts i make are much easier to construct in PartDesign (mechanical engineering).
Greetings
user1234
Postby NormandC » Sun Jun 10, 2018 5:02 am
It's simple: PartDesign does not support multiple solids. There is nobody willing to work on this. It might take a long time (years possibly) before that changes.
Here are some explanations on the subject, you'll need to use a translation service to translate it from German. https://forum.freecadweb.org/viewtopic. ... 40#p198094
