OS: Ubuntu 17.04
Version: 0.17.12113 (Git)
Build type: Unknown
Hash: 09737f2db30ad13ce5600b2c2dcd4786c7699d26
Python version: 2.7.13
OCC version: 7.1.0
1. Create new FreeCAD document and switch to Part Design
2. Create New Body
3. Create New Sketch and base it on XY plane. Draw something, eg. circle with 50mm radius
4. Pad the sketch, and make direction reverse, so it is extruded downwards. 5. Then I will make another sketch on XY plane, eg. 10mm circle with center 40 mm from origin.
6. Pad second sketch 7. Now, I will make Polar pattern of second pad, eg. full circle with 4 occurences. 8. I will create a new sketch on XY eg. 20mm circle in origin. Sketch is placed before Polar pattern!!! 9. When I Pad or Pocket this sketch, it overrides Polar pattern... 10. If Pocket is manually moved behind Polar pattern (Move object after other object), I get expected appearance.
11. If you try to add New sketch or additive primitive, it will, again, be placed before Polar pattern...
Is anyone else experiencing this?
