- Load the attached Crash3.FCStd file.
- Navigate to the "Fusion/Body" and delete the last "Pocket1". -> crash.
OS: "Arch Linux"
Version: 0.17.12364 (Git)
Build type: Debug
Hash: 5632f17d813ca74487a045416c7937fcc9103fe3
Python version: 2.7.14
Qt version: 5.9.1
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
Note:
- Setting Tip manually to a different primitive or removing the topmost Union-Fusion beforehand prevents the crash.
- I managed to get to this state by removing multiple primitives before. I can attach the very original file too if it would help.
- It appears the Pocket1's base is not the Pad1 but some other primitive I've deleted earlier. But I don't see where I can change a pad's base now. Not sure if this is related to the crash or not.
Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault.
0x00007fffbdce03e6 in BOPDS_DS::Init() () from /opt/oce/lib/libTKBO.so.11
#0 0x00007fffbdce03e6 in BOPDS_DS::Init() () from /opt/oce/lib/libTKBO.so.11
#1 0x00007fffbdd49d42 in BOPAlgo_PaveFiller::Init() () from /opt/oce/lib/libTKBO.so.11
#2 0x00007fffbdd49a91 in BOPAlgo_PaveFiller::PerformInternal() () from /opt/oce/lib/libTKBO.so.11
#3 0x00007fffbdd49992 in BOPAlgo_PaveFiller::Perform() () from /opt/oce/lib/libTKBO.so.11
#4 0x00007fffbdcd5d5e in BRepAlgoAPI_BooleanOperation::Build() () from /opt/oce/lib/libTKBO.so.11
#5 0x00007fffc34519d2 in Part::MultiFuse::execute (this=0x5555596d7b10) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Mod/Part/App/FeaturePartFuse.cpp:147
#6 0x00007ffff6c82ec4 in App::DocumentObject::recompute (this=0x5555596d7b10) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/DocumentObject.cpp:83
#7 0x00007fffc346adec in Part::Feature::recompute (this=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Mod/Part/App/PartFeature.cpp:83
#8 0x00007ffff6c5035c in App::Document::_recomputeFeature (this=this@entry=0x55555804d060, Feat=0x5555596d7b10) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:2306
#9 0x00007ffff6c5557f in App::Document::recompute (this=0x55555804d060) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:2205
#10 0x00007ffff6cabc35 in App::DocumentPy::recompute (this=this@entry=0x555555c87950, args=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/DocumentPyImp.cpp:408
#11 0x00007ffff6cabdb8 in App::DocumentPy::staticCallback_recompute (self=0x555555c87958, args=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/DocumentPy.cpp:1718
#12 0x00007ffff6476449 in PyEval_EvalFrameEx () from /usr/lib/libpython2.7.so.1.0
#13 0x00007ffff64d5886 in PyEval_EvalCodeEx () from /usr/lib/libpython2.7.so.1.0
#14 0x00007ffff64eb05a in PyEval_EvalCode () from /usr/lib/libpython2.7.so.1.0
#15 0x00007ffff64f27f1 in run_mod () from /usr/lib/libpython2.7.so.1.0
#16 0x00007ffff64f4588 in PyRun_StringFlags () from /usr/lib/libpython2.7.so.1.0
#17 0x00007ffff688798a in Base::InterpreterSingleton::runString[abi:cxx11](char const*) (this=<optimized out>, sCmd=0x55555981c7d8 "App.getDocument(\"Crash3\").recompute()") at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Base/Interpreter.cpp:232
#18 0x00007ffff737bfea in Gui::Command::doCommand (eType=eType@entry=Gui::Command::Doc, sCmd=sCmd@entry=0x7ffff7a1eb70 "App.getDocument(\"%s\").recompute()") at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/Command.cpp:475
#19 0x00007ffff738bb32 in StdCmdDelete::activated (this=<optimized out>, iMsg=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/CommandDoc.cpp:1162
#20 0x00007ffff738084b in Gui::Command::invoke (this=0x555555a549f0, i=0) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/Command.cpp:300
#21 0x00007ffff570e766 in QMetaObject::activate(QObject*, int, int, void**) () from /usr/lib/libQt5Core.so.5
#22 0x00007ffff5c85523 in QAction::triggered(bool) () from /usr/lib/libQt5Widgets.so.5
#23 0x00007ffff5c87d46 in QAction::activate(QAction::ActionEvent) () from /usr/lib/libQt5Widgets.so.5
#24 0x00007ffff5c88626 in QAction::event(QEvent*) () from /usr/lib/libQt5Widgets.so.5
#25 0x00007ffff5c8be2c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5
#26 0x00007ffff5c93906 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5
#27 0x00007ffff734f2d9 in Gui::GUIApplication::notify (this=0x7fffffffd030, receiver=0x555557baa640, event=0x7fffffffc8d0) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/GuiApplication.cpp:91
#28 0x00007ffff56debb0 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib/libQt5Core.so.5
#29 0x00007fffefe800e9 in QShortcutMap::dispatchEvent(QKeyEvent*) () from /usr/lib/libQt5Gui.so.5
#30 0x00007fffefe801be in QShortcutMap::tryShortcut(QKeyEvent*) () from /usr/lib/libQt5Gui.so.5
#31 0x00007fffefe2dd6d in QWindowSystemInterface::handleShortcutEvent(QWindow*, unsigned long, int, QFlags<Qt::KeyboardModifier>, unsigned int, unsigned int, unsigned int, QString const&, bool, unsigned short) () from /usr/lib/libQt5Gui.so.5
#32 0x00007fffefe4db98 in QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*) () from /usr/lib/libQt5Gui.so.5
#33 0x00007fffefe52d06 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) () from /usr/lib/libQt5Gui.so.5
#34 0x00007fffefe2a48c in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt5Gui.so.5
#35 0x00007fffe5045ce1 in ?? () from /usr/lib/libQt5XcbQpa.so.5
#36 0x00007fffee805a57 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#37 0x00007fffee805c88 in ?? () from /usr/lib/libglib-2.0.so.0
#38 0x00007fffee805d1c in g_main_context_iteration () from /usr/lib/libglib-2.0.so.0
#39 0x00007ffff5739041 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt5Core.so.5
#40 0x00007ffff56dcfdb in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQt5Core.so.5
#41 0x00007ffff56e6028 in QCoreApplication::exec() () from /usr/lib/libQt5Core.so.5
#42 0x00007ffff730105d in Gui::Application::runApplication () at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/Application.cpp:1895
#43 0x0000555555556fd3 in main (argc=<optimized out>, argv=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Main/MainGui.cpp:247
std::__detail::_List_node_base::_M_hook (this=0x5555598810f0, __position=__position@entry=0x48) at /build/gcc/src/gcc/libstdc++-v3/src/c++98/list.cc:131
#0 std::__detail::_List_node_base::_M_hook (this=0x5555598810f0, __position=__position@entry=0x48) at /build/gcc/src/gcc/libstdc++-v3/src/c++98/list.cc:131
#1 0x00007ffff6c6a7cd in std::__cxx11::list<boost::subgraph<boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS, boost::property<boost::vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property>, boost::property<boost::edge_index_t, int, boost::property<boost::edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> >, boost::property<boost::graph_name_t, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, boost::property<boost::graph_graph_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> > > >, boost::listS> >*, std::allocator<boost::subgraph<boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS, boost::property<boost::vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property>, boost::property<boost::edge_index_t, int, boost::property<boost::edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> >, boost::property<boost::graph_name_t, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, boost::property<boost::graph_graph_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::ba
::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> > > >, boost::listS> >*, std::allocator<boost::subgraph<boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS, boost::property<boost::vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property>, boost::property<boost::edge_index_t, int, boost::property<boost::edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> >, boost::property<boost::graph_name_t, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, boost::property<boost::graph_graph_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> > > >, boost::listS> >*> >::push_back (__x=<optimized out>, this=0x48) at /usr/include/c++/7.2.0/bits/stl_list.h:1123
#3 boost::subgraph<boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS, boost::property<boost::vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property>, boost::property<boost::edge_index_t, int, boost::property<boost::edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> >, boost::property<boost::graph_name_t, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, boost::property<boost::graph_graph_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_vertex_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::property<boost::graph_edge_attribute_t, std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std---Type <return> to continue, or q <return> to quit---
::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, boost::no_property> > > >, boost::listS> >::create_subgraph (this=0x0) at /usr/include/boost/graph/subgraph.hpp:175
#4 0x00007ffff6c53567 in App::Document::GraphCreator::addExpressionSubgraphIfNeeded (this=this@entry=0x7fffffff9f20, obj=0x555559778fd0, CSsubgraphs=CSsubgraphs@entry=true) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:351
#5 0x00007ffff6c57d33 in App::Document::GraphCreator::addSubgraphs (this=0x7fffffff9f20) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:537
#6 App::Document::GraphCreator::build (this=0x7fffffff9f20) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:257
#7 App::Document::GraphCreator::GraphCreator (_d=<optimized out>, this=0x7fffffff9f20) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:246
#8 App::Document::exportGraphviz (this=this@entry=0x555558043290, out=...) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/App/Document.cpp:801
#9 0x00007ffff764d8de in Gui::GraphvizView::updateSvgItem (this=this@entry=0x55555991f5f0, doc=...) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/GraphvizView.cpp:266
#10 0x00007ffff764ed9f in Gui::GraphvizView::GraphvizView (this=0x55555991f5f0, _doc=..., parent=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/GraphvizView.cpp:183
#11 0x00007ffff7384bc5 in StdCmdExportGraphviz::activated (this=<optimized out>, iMsg=<optimized out>) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/CommandDoc.cpp:383
#12 0x00007ffff738084b in Gui::Command::invoke (this=0x555555a525c0, i=0) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/Command.cpp:300
#13 0x00007ffff570e766 in QMetaObject::activate(QObject*, int, int, void**) () from /usr/lib/libQt5Core.so.5
#14 0x00007ffff5c85523 in QAction::triggered(bool) () from /usr/lib/libQt5Widgets.so.5
#15 0x00007ffff5c87d46 in QAction::activate(QAction::ActionEvent) () from /usr/lib/libQt5Widgets.so.5
#16 0x00007ffff5de74f5 in ?? () from /usr/lib/libQt5Widgets.so.5
#17 0x00007ffff5deea3c in ?? () from /usr/lib/libQt5Widgets.so.5
#18 0x00007ffff5def8a4 in QMenu::mouseReleaseEvent(QMouseEvent*) () from /usr/lib/libQt5Widgets.so.5
#19 0x00007ffff5ccdd48 in QWidget::event(QEvent*) () from /usr/lib/libQt5Widgets.so.5
#20 0x00007ffff5df1b34 in QMenu::event(QEvent*) () from /usr/lib/libQt5Widgets.so.5
#21 0x00007ffff5c8be2c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5
#22 0x00007ffff5c93e81 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5
#23 0x00007ffff734f2d9 in Gui::GUIApplication::notify (this=0x7fffffffd030, receiver=0x555557c1e130, event=0x7fffffffc390) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/GuiApplication.cpp:91
#24 0x00007ffff56debb0 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib/libQt5Core.so.5
#25 0x00007ffff5c92e0a in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /usr/lib/libQt5Widgets.so.5
#26 0x00007ffff5ce8c62 in ?? () from /usr/lib/libQt5Widgets.so.5
#27 0x00007ffff5ceb671 in ?? () from /usr/lib/libQt5Widgets.so.5
#28 0x00007ffff5c8be2c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5
#29 0x00007ffff5c93906 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5
#30 0x00007ffff734f2d9 in Gui::GUIApplication::notify (this=0x7fffffffd030, receiver=0x7fffdc00d2e0, event=0x7fffffffc990) at /tmp/makepkg/freecad-qt5-git/src/freecad-qt5-git/src/Gui/GuiApplication.cpp:91
#31 0x00007ffff56debb0 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib/libQt5Core.so.5
#32 0x00007fffefe511c4 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) () from /usr/lib/libQt5Gui.so.5
#33 0x00007fffefe52d26 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) () from /usr/lib/libQt5Gui.so.5
