wrong axis moving helix into body
Vincent B
Post by Vincent B »
Im trying to move an helix into a body to make a thread. Its changing his axis X to Z. How to fit it on the X axis? is it a bug?
OS: Windows 8.1
Version: 0.17.12619 (Git)
Hash: b3631e134be8bfade0534f2dc0ee668ae71a223f
Python version: 2.7.8
OCC version: 7.1.0
Locale: French/France (fr_FR)
testhelix.FCStd
(9.63 KiB) Downloaded 49 times
Re: wrong axis moving helix into body
I succeeded in importing the helix horizontally as a shapebinder into the body. I succeeded as well to use it as path for a sweep. However, the sweep did not work, perhaps you have more luck following this idea.
And I would like to see the result.
Vincent B
Post by Vincent B »
Its Ok, its succeded with a shapeBinder. Thanks
testhelix.FCStd
(219.39 KiB) Downloaded 47 times
What I had tested and could not get working was the additive pipe.
I can open your file. When I double click the subtractive pipe FreeCAD crashes. When I delete and recreate the sweep the triangle is in the middle of the cylinder and I get a fancy spiral. I will update to the most recent version and retry.
Similar situation with the current Ubuntu:
Crash when double clicking the subtractive pipe.
When I delete the sweep the swept triangle is in the middle:
Bildschirmfoto 2017-11-26 um 16.27.18.png (44.2 KiB) Viewed 1116 times
When I recreate the sweep, the triangle jumps to the correct position and I can create the sweep like yours.
When I reopen the sweep the triangle is in the middle again and stays there after ok. The result is this:
Bildschirmfoto 2017-11-26 um 16.31.47.png (19.46 KiB) Viewed 1116 times
I cannot paste my FreeCAD info, it makes my browser hang, perhaps it is a problem with my new virtual machine and its clipboard copy function, but my version is 0.17.12643
